Question about Dirt Devil Vacuums
Why does my dirt devil still stop working after 10minutes,and the ffilters are still clean and hose?I've only had it 5months and is ment to be for animal hairs as well but I can only use for a few min
    Master:
  • 923 Answers
What do you mean by it stops working? Does the motor stop running, or does the motor keep running but it stops picking up things?
Posted on May 12, 2017
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Posted on Jan 24, 2008
SOURCE: dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Posted on Mar 28, 2008
SOURCE: DIRT DEVIL CLOGGING IN THE HOSE
What is the solution to this problem ?
Posted on Sep 19, 2008
  • 294 Answers
SOURCE: Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Posted on Jan 24, 2009
SOURCE: dirt devil purpose for pets vacuum quit working
The motor overheats from the filter being clogged underneath the canister or the canister or both are clogged-without the air flow the motor overheats and shuts off as a precautionary measure.By letting the motor cool off it will start again but will turn off shortly if the filters are not properly cleaned.Hope this helps everyone.
Rob
Posted on May 14, 2009
Got a dirt devil upright I've cleaned out the Short hose extension hose also cleaned under bottom plate checked belt looks good don't see no holes or cuts in hoses no cracks in bagless container
Hello, Im assuming that your unit has no suction. If this is the case, it is still plugged. Run a stiff wire through all the hoses, starting at the on behind the bristle brush. Make sure all the bagless filters are completely cleaned.
Mar 30, 2017 | Dirt Devil Vacuums
Why is my Dirt Devil Vacuum Hose lacking suction?
I have a Dyson and was having a similar problem some time back. I found out these bagless systems still have a filter that picks up the fine dust to keep it contained. Find out where yours is located and beat the dust out of it really good or just replace it.
Hope this helps.
Mar 10, 2014 | Dirt Devil Vacuums
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
No suction
the hose can clog up insid where you cant see it my husband takes it off and runs water thru it to flush stuff out lets it dry then reconnects it
Sep 18, 2012 | Dirt Devil Featherlite Bagless Vacuum...
My dirt devil breeze shoots out dirt from vent
try cleaning the filters and clear out hoses, sounds like it has backed up inside, also if the filters aren't clean it can loose suction.
Nov 01, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Hose gone on Dirt Devil DD2821 need replacement
http://www.espares.co.uk/part/vacuum-cleaners/dirt-devil/dd2821/p/1086/112/0/970655/478317/universal-flexible-clean-.html
This is the only hose "Dirt Devil" has listed for your model number.
Dec 12, 2009 | Dirt Devil Vacuums
Dirt Devil Purpose for Pets won't ****!!!!
The filters will need cleaning. Make sure the entire cone filter has been gently brushed getting rid of all dust. Also check in the main dust channel where the beater bar is. It may well be clogged and best to check the hose too.
Jan 31, 2009 | Dirt Devil Featherlight Bagless Upright...
Dynamite Dirt Devil Hose
I figured out how last night.
Take a screw driver and unscrew the screw on the top of hose and take the hose out and take a pen or something long enough with grip to get all of the junk out.
The circulation still isn't as strong though.
Dec 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
DIRT DEVIL VISION BAGLESS UPRIGHT
Check further down, by the brush roll, the inlet may be clogged, or something like a nail or pin wedged sideways in the hose, and catches debris and clogs up. This has a one year warranty, if you still can't firgure it out, take it to a warranty shop and take proof of purchase with you.
Dec 29, 2007 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
60 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Nick Olsen
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
