Question about Lands Phones
When voicemail is played, can't access to leave message from the caller. voicemail states press #, but then states information is incorrect. Service provider states all ok with phone service.
SOURCE: Caller ID Light Won't Stop Blinking on Base of KX TC1713 Phone
Solved this myself simply by scrolling through all the Caller ID entries from recent calls . . .
Posted on Mar 02, 2008
Nova_1
  • 196 Answers
SOURCE: iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Posted on Sep 07, 2008
cnavarro
  • 2460 Answers
SOURCE: Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Posted on Jan 08, 2009
SOURCE: Uniden CXA15198 not showing caller id
Had a similar issue with a brand new DECT2035 uniden phone, displaying incoming call not caller ID.
Checked my old uniden phone, and it was receiving CID. So I connected my DECT2035 to that line and then lo and behold I got my CID.
After further investigation I found that CID on my dect phone wont work if its using a shared filter (ie. adsl/phone splitter). Had to find an unfiltered splitter and then just put a phone filter (that I got with my adsl modem) onto the line that is directly connecting the phone. and then WOOHOO I have caller ID.
Hope this helps you... I got my wife a little cranky over this one cos it took me over an hour and a half to try and sus this one out =)
Posted on Apr 30, 2009
SOURCE: CD445 voice message icon won't stop flashing
This feature is country dependent and may not
appear in some countries.
If you have subscribed to the voicemail service
from your local service provider, icon turns
on when you have a new message in your
mailbox. After you have accessed to all the new
messages, icon will turn off automatically. If
you find that the message waiting indication
cannot be turned off by the network, you can
still turn off the message waiting indication with
your phone by the following step :
In idle mode, if voice mail waiting icon is on,
long press the redial key to turn off the voice mail waiting
icon.
Once you choose to delete the message waiting
indication, all the other handsets registered to
the same base station will turn off the message
waiting indication accordingly.
Posted on Aug 30, 2009
How do I make the green flashing light on the phone go away?
Blinking Light
Two reasons the light on top of your screen might be blinking or on steady.
  • You do not have a voicemail key programmed and the voicemail is alerting you of a new message. Simply dial *8 and check your mailbox.
  • Message waiting has been activated. To cancel:
    • leave handset hung up
    • press call1 key
    • dial 873
    • press speaker key
Blinking light on top of Display NEC Aspire
Nov 13, 2014 | NEC Lands Phones
I am having problem with leaving messages. Everytime someone try to leave msg..voicemail say your memory is full, please hangup..but there were no messages in there..I also turned the machine off to see if...
Deleting messages (memory may be full).
Verify you do not have old messages on the the system. After the system plays all new messages, press Play/Stop again or from the handset Select 2:Play.If you find messages, delete them during or after they play.
After you listen to your messages, the voice message icon turns off. If it doesn't or if you can not receive messages, you should try to reset it: With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes.
Make sure the Record Time is not set to Announce Only.
Jun 20, 2011 | Uniden DECT 6.0 Cordless Phone
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
It will not let someone leave a message on our answering machine??
In reading this issue I am not sure if you are referring to your voicemail that is provided by your cellular provider, or if cell phone callers are unable to leave a message on your land line answering machine, so I will answer both of those just incase. If you are referring to your cellular service and callers are not able to leave you a voice message, then there could be a couple of issues at hand here. The first of which is that your voice mail box may be full and cannot accept any more messages, If this is the case then you will need to delete some of the older messages by pressing and holding # 1 on your wireless handset and selecting the messages that you want to delete from the voicemail system. If that is not the issue then you will need to place a test call to your cellular device and let it rollover to voicemail and see what it is that the callers are being told. Sometimes there will be an error message. If this is the case then you will want to write that message information down and contact your service provider so that they can resolve the issue. If you call your cellular device and let it rollover to voicemail and the system tells you to enter the subscribers telephone or mailbox number, then what you have is called a "round tree message" and this means that there is an issue with the server that handles the voicemail for that celluar provider and their technical support team will handle the issue by reseting your voicemail. If they do this you may lose all of your messages, that is the downside. The upside is that callers will then be able to leave you messages.
If this is referring to your land line answering machine, I would recommend unpluging it, letting it sit for a minute and plugging it back in. You may also want to make sure that you do not have caller ID call block initated on your home phone, which will tell callers that there call has been delivered successfully but the party they are calling does not accept calls from parties who have their number blocked.
I hope that this information was helpful
Jan 14, 2011 | Cell Phones
How do I retrieve my voicemail from a land line
Access your voicemail from your mobile cell phone and record a personalised voicemail greeting.
Now call your number from a landline, and when you hear your voicemail greeting prompt you to leave a message, press the required key sequence to access your voicemail from the landline.
The required sequence is dependent on which network/service provider you are using.
If you let me know which network, i can give you more detailed information.
Jan 06, 2010 | Motorola Cell Phones
How do you retrieve a voicemail from the vtech cordless phone model #CS5111?
Your phone does not have an internal answering machine/voicemail function. It only allows you to retrieve voicemail messages if you subscribe to voicemail service through your telephone service provider. Access and other features vary by telephone company and location, so you need to contact your phone company for specifics. The voicemail light on your phone lets you know if you have new messages on your phone company system. To disable this light if you do not subscribe to this service:
- Press PROG
- Use the up/down arrow keys to select CLR VOICEMAIL
- Press SELECT. The screen displays CLEAR? and YES flashes.
- Press SELECT to confirm. You will hear a confirmation tone.
Need the full manual for your phone? You can download/print it here:
http://www.vtechphones.com/docMgt/public/art/314058/cs5111_manual.i7.pdf
Dec 18, 2009 | Vtech V-Tech i5821 5.8GHz Cordless Phone...
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Nov 08, 2009 | Uniden Cordless Phone
    Full memory
    Erase Messages
    Single Messages
    You can erase a message itself, leaving the Caller ID information.
    • While the message is playing, press and release DELETE. The unit erases the current message and announces, "Message erased."0
    All Messages
    You can also erase all the old messages only, leaving the new messages and Caller ID information.
    While the unit is in ready-to-answer mode, press and hold DELETE until the unit announces, "Messages erased."
    • New messages can not be erased in this way. To erase new messages, play them then press DELETE during play back.
    Here is a link for the manual for your phone:
    http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
    May 09, 2009 | GE 29897GE1 Corded Phone
    Message Box is full. How do I erase?
    Erase Messages
    Single Messages
    All Messages
    Apr 26, 2009 | GE 29897GE1 Corded Phone
    Voicemail answering
    Contact your mobile service provider's helpdesk for further assistance on activating your VM
    Aug 28, 2008 | Motorola Mobility RAZR V3
    Lands Phones Logo
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
