Question about The Computers & Internet
How far can you go on a full charge how long will the battery stay chaRGED
  • The Master
  • 1,830 Answers
Be specific. What are you talking about? What type of device is it?
Posted on May 12, 2017
Noticed battery and brake light on my 01 montero sport lxs. Was told I need a new alternator. My car never died nor had a problem starting. Is there another reason for those two lights to be on?
As a first step to checking make sure your battery is full of electrolyte and give it a full charge to see if that causes the battery light to go out. The two lights may not be connected to alternator fault. If, when the battery is full charged, the battery light goes out and stay out you will have got to the bottom of the issue. You need to do this as soon as possible because the brake warning light is a major issur, If charging the battery cures the battery warning light but not the brake light then you have a brake problem.
If charging the battery puts both lights out and they stay out then it is probably as the garage argues.....there is no reason for a lrake light to go out if no brake work has been done.
You are o a path of investigation that must be carried out quickly in case the brake warning light is a valid warning.
Wouldn't drive too far or fast till you have resolved the matter
good luck
Jul 04, 2015 | Cars & Trucks
Car won't start gauges quiver
check your main battery terminals for corrosion and earth strap frm battery to earthing point may be needs replacing or check battey for full charge may be you don't drive it far enough to charge battery short trips don't charge batteries fully or attach a solar panel trickle charger
Aug 06, 2014 | Charging & Starting Systems for Pontiac G3
I have 4 months with my Acer Aspire 5251-1513 and I have noticed 1 week ago that my battery will not charge to full capacity. When it reaches 79% it stays there and will not charge from there, what should...
your battery may have become "Imprinted".
Run the system on battery until the battery is completely dead, then fully recharge it as far as it will charge, then exhaust the battery again. If the battery doesn't recover it's full capacity, then contact Acer for a replacement as the battery should have a 1 year warranty
Jan 10, 2011 | Computers & Internet
My Dewalt 14.4 volt nicad battery will not power my battery drill dispite having 13.8 volts across the terminals. Also when the battery is placed in it charger the light pulsates three times and then stay...
Probably, the battery has seen better days. After full charge, the battery should read more than 14.4 volts until used for a little while. You should either replace the battery or have it rebuilt with either Ni-cads or much-better lithium ion cells. Check with www.primecell.com for information. I had this done for a Skill drill battery (Li-ion) and the charge holds for long periods of time when stored and lasts far longer when used. The original charger worked ok for this modification. Hope this helps!
Nov 16, 2010 | Garden
The battery wont stay charged .when you plug it in to charge the green light comes on ,when fully charged the red light is on,when you turn it on no power
If the charger is automatically giving you a green light when you plug in the charger, the batteries are most likely damaged and will no longer take a charge. This can happen when the power chair is stored and the batteries are not charged for a while. The green light on the charger indicates the battery is full, but instead of being full of power, its full of crud. Try to replace the batteries and see if that will solve the problem.
Mar 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Turn off actomatically, cannot turn on so far.
Your battery may be too low to allow charging it and "starting" your computer at rhe same time.
Remove the battery and clean the contacts on the battery and the laptop.
1. Plug in the laptop power adapter with no battery in the laptop.
2. Turn ON computer. It should stay turned on.
3. After Windows settles, insert battery.
4. The computer will stay powered on.
5. Allow to charge.
Sep 08, 2009 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
After charging d battery when we remove cabele
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
Jul 29, 2009 | Adapters.com Computers & Internet
I have a Cyber DSC F-828 and it will not turn on indacator light flashes after charging and reseting but wiil not stay on. Battery has a full charge. Help thanks
i have a Cyber DSC F-828 and it will not turn on indacator light flashes after charging and reseting but wiil not stay on. Battery has a full charge. Help thanks
Dec 19, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
My motorola krzr only stays on for a few minutes after a full charge.
Yes, you should resort to a new battery, coz the old one is exhausted. Overnight charging is not a good habit. You should charge 2-3 hours until full, and remove the charger
Sep 27, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Gps 276C doesn't charge fully
Garmin has updates for this issue on the website but it doesn't fix all the units. Mine for example still does the whole "charge complete" thing when showing 1/2 a battery. The funny thing is I let it drain and the unit stays on for about 10 hours after it says the battery is dead. Garmin is working on a new fix and they said it should be up in about a week.
Nov 22, 2007 | Garmin GPSMAP 276C GPS Receiver
Computers & Internet Logo
43 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
