Question about Speakman Plumbing
Speakman censor faucet doesn't work what could be the problem?
2 Suggested Answers
SOURCE: Speakman shower faucet washer replacement
Keep unscrewing, to the left. Past the point that would normally be the full "on" position for the valve. I've just removed my Speakman Kent shower stem, and because it is damaged where the washer attaches, will have to replace it (both of them).
Posted on Jan 10, 2010
How do i fix my leaky shower? It's an old house and I have a speakman mixometer shower handle.
change the rubber seal in the leaking part. rubber seals can go at anytime, but the older they get the weker and brittler they go.
Feb 03, 2018 | Speakman Home
How do I determine the model number of Speakman Shower faucet?
Before replacing parts, check the diverter for corrosion that prevents free operation.
Jun 19, 2014 | Speakman Home
Price pfister classic series kitchen faucet stops between double sinks and will not turn into left sink.
Shut off the water under the sink, loosen the nut for the faucet careful not to strip it. Try to move the faucet into the desired position, if it works clean the areas of the connections that you can get to and tighten back down carefully so that the connections are not stripped and its not too tight. Make sure it moves as desired, turn the water back on. If it doesn\'t move after the main nut is loosed, then I suggest dismantling the faucet, clean it all with alcohol and try again. If not a new faucet may be in order, it is hard to properly replace the inside portions of a faucet without proper training, a handy type person could though. I suggest if internal faucet repair is attempted that you take the parts with you to the store and compare carefully. Good luck!
Oct 25, 2013 | Price Pfister Plumbing
How to remove restricter from Speakman showerhead s2252
You would destroy the shower head trying to remove the part.
Jan 09, 2012 | Speakman S-2251 Showerhead
We purchased a 16927 Series SSSD 5 years ago. the faucet doesn't swivel on the base, so the nut securing the faucet to the sink continues to loosen under the sink. I've tried lubrication, I've...
There is a possibility of corrosion between swivel and base. Remove faucet and take to a work table and try and twist swivel spout off. I t may be tight, but the unit is not satisfactory and may need replacement. I have repaired such faucets before and many have been cheaper to replace. There a o rings between spout and body if you get it apart check mating surfaces any erosion discard unit. If OK replace o rings and use silicon grease. No petroleum products as this will cause o rings to swell. Good Luck
Nov 16, 2017 | Plumbing
Leaking water from head when turned off
It is normal for the water to trickle for a little time while the water drains from the shower head. If this continues you will need to repair the shower faucet
Jun 25, 2010 | Speakman S-2252-2 Anystream 6 Jet Dual...
Speakman Luxury 8 not 8 anymore!
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Nov 12, 2009 | Speakman 8 jet anystream 2000 luxury 8...
I have a 1928 home with a speakman mixometer, the water constantly leaks from the shower handle, also the cold water faucet leaks when it is turned on only. Thanks for your support
http://www.plumbingspecialties.com/downloads/PPfistertoSpeak.pdf......this website offers several blow up diagrams of the mixometer. More than likely it is the packing and all you have to do is tighten the packing nut. You can do this by removing the handle and tightening the nut below it. You may have to remove the escuteon to gain access but the blow up should help you. If you have any questions just ask.
Thx
Ken
Sep 05, 2009 | Home
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
there may be two nuts,one for the stem and one for the stem barrel.if not then the stem does just screw out,may just have a build up of something on it,try and working it back and forth to try and break it loose,careful not to damage anything.
May 23, 2009 | Plumbing
Plumbing Logo
41 people viewed this question
Top Speakman Plumbing Experts
Paul Carew
Tom Chichester
Are you a Speakman Plumbing Expert? Answer questions, earn points and help others
