Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Security camers not displaying on
I have installed 3 security camers on the outside of my home and cannot get them to display the images on m Sharp LCD TVs. I have all three camers going into one modulator. The images dispay fine on seven other TVs in my home but when I connect to the Sharp and select the appropriate input all I get is a black screen. Please help.
  • 57 Answers
Re: Security camers not displaying on
Try going to that input and changing ntsc/pal or make sure your closed captions are off.
Posted on Dec 10, 2007
0 characters
3 Points
I switch off my TV sharp and when I switch it on again a password appear on my display screen
The password is between 0000-9999 unless you remember the code or you find the person who input the security code
Dec 01, 2015 | Sharp Flat Panel Televisions
How to fix my sharp aquos LC42D69U lcd tc
Use coldspray to find the bad component abad soldering or a few bad capacitors in the (mains) powersupply . knock and bend the electric print some little the beginning is the powersupply
SHARP LC 32D59U LC 42D69U Service Manual free download schematics eeprom...
Sep 24, 2015 | Sharp Aquos Flat Panel Televisions
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
Mar 14, 2011 | Sharp Flat Panel Televisions
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp Aquos LC-37BX6N - no display. On switching
Off/On The Power switch sudden 4 Straight lines appear on the screen ! what is that & why ?
Oct 05, 2009 | Sharp Flat Panel Televisions
Burned images
Unfortunately, you can't, unless you replace the screen, sorry to be the bearer of bad news, I suggest in future do not have any display features like time, channel number and so on displayed constantly, or if you are using it as advetrtising or security that you change the image at intervals....Phil
May 19, 2009 | Philips Flat Panel Televisions
Picture size
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
Digital Setup
This setting allows you to set the image of Digital
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
All broadcasts will be converted
and displayed in the 1080i
Nov 27, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
2 Press PIC. FLIP to change the
Setting the PICTURE FLIP on the
MENU screen
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
4 Press c/d to select the desired
picture flip setting, and press
5 Press MENU to return to the main
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
No Image on Screen
Since you have a comcast info on screen your system is fine.Call comcast to fix your box.
Mar 02, 2008 | Flat Panel Televisions
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
63 people viewed this question
Top Sharp Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Are you a Sharp Flat Panel Television Expert? Answer questions, earn points and help others
