Does the plate in front of the lint cleanout come off?
How to get Tooth brush from inside in the lent clean out
Get a 2' peice of plastic tubing 1/2" in diameter, and hold it on one end by a running vacuum hose.Stick other end lint cleanout area.
Depends on your model, but some units have a front kicker panel that removes and you can disassemble the lint basin.
Jan 22, 2014 | Dryers
Washer isn't draining and gives off flashing light beeps help!
Remove the lower front panel to access the drain pump.
Remove the drain pump and cleanout the lint.
Mar 02, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
My washer will not drain WJR 4170
If you can here the pump humming then it may be plugged. remove lower kick plate ..There is a cleanout on the front of the pump remove counter clock wise .see if there is any goodies in there..remove the items give it a try with front kick plate removed that way you can test for power at the pump if cleaning it don;t work...Good luck if I helped you please vote Thank you
Feb 02, 2011 | General Electric Washing Machines
It won't drain.I think maybe it's the pump.What is the best way to get the water out of the tub without making a big mess?
Take lower kick plate of unit/ pump is behind it..there is a cleanout at the front of pump lay some towels down slowly turn cleanout from pump couter clockwise little water at a time..if it is pluged that may be why it is not draining ...good luck if you need more help just ask.....If I helped you please vote/// good luck
Feb 02, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Where is the lint trap on the front loader
There is no lint trap. There is a coin catcher on the pump. The design of the wash action on a front loader is such there is less lint than on standard machines. One of the bennies of the design.
Eric
May 20, 2010 | Kenmore Elite 45986 Front Load Washer
I have an Axxis+ washer/dryer. The washer is giving me an F:34 error, any ideas?
you can try this I had one of these the other day. On the bottom front of the washer you will find a round access cover, rotate it to the right to remove it, inside you will find a green cord to manually unluck the door, pull it down. Door should now be unlocked. Chances are the door won't unluck because the wash water is not draining from the washer due to a clogged drain pump. Right behind that round access cover is the water pump. Before you open the pump cleanout, soak up all the remaining water inside the wash basket of the machine, or use a wet dry vacuum to vacuum up the water. Have a shallow pan and lots of bath towels to catch the water when you open up the drain pump cleanout. Check the drain pump cleanout for lint, small socks, coins and whatever gets left in pockets of clothes.http://servicetechhelp.com/discus/messages/2801/65423.html?1241057606
May 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Need to clean lint out of the front cover.
You need to use a Hoover Nozzle Cleanout Tool for the SteamVac
You can find the part by clicking the link. Please give positive feedback.
Cleanout tool Link
http://www.usavacuum.com/Hoover-Nozzle-Cleanout-Tool-SteamVac-p/39514001.htm
Jan 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Bosch front load washer display says drainage blocked. What do i do?I already checked the exterior drainage hose
look for a front plate lower right corner / remove plate and inside is 3 in drain cleanout . ccw will remove and clean basket . cw to reinstall . should correct problem. mm
Dec 03, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer won't drain
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Aug 05, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
