Question about Kenmore Ovens
How wide is a Kenmore single wall oven model 790-4052-4400
Is it considered a 24" or higher wall oven?
Powerman
  • 68 Answers
SOURCE: oven showing F2 fault
I concur with Catriver. F2 means that the oven temperature has exceeded a preset threshold. It could be for any of the following reasons: Welded relay contacts. Cooling fan stalled or blocked air flow to rear of unit. High resistance in oven sensor leads/high resistance in connectors especially at sensor in rear. There could be an open thermal switch in the yellow leads. The oven sensor would measure around 2650 ohms at the "clean temperature".
Posted on Apr 22, 2007
rickzilla
  • 706 Answers
SOURCE: Wall Oven
Hello zultar777,
The oven will fit however it will stick out a few inches beyond the front of the cabinet. If that looks ok to you, then go for it.... Is ther any way you can open up the wall behind the oven to allow the new oven to recess in deeper? You may want to investiaget that option. If the wall behind the stove is a non- weight bearing wall..you should be able to cut it opne and remove a section of the wall studs.. also..check to see if the new oven uses any mounting tabs to lock it in place.. if it does and these are close to the front of the oven, you may have to jury rig something to secure the oven.. It may or may not use them thou so check with the manufacturer..
Good Luck
Regards,
Rick
Posted on Dec 04, 2008
SOURCE: oven will not heat to temperature setting
Called a Sears Tech to check it out. He found it was the control board/clock/timer. He said it was the first one he had seen go bad, and was happy I had the part number from your site, as it did not yet appear on his computer.
Posted on Jan 02, 2009
  • 8 Answers
SOURCE: Kenmore electric in wall oven.
might be a bad temp sensor
Posted on Jul 14, 2009
  • 491 Answers
SOURCE: Kenmore model 36275575691 oven rack is
GO TO A CATERING OUTLET AND ASK FOR OVEN RACKS ; ALSO CONTACK SUPPLIER TO SEE HAVE THEY ANY IN STOCK.
Posted on Oct 17, 2009
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
How do I start the clean cycle
The "S" in the model number stands for standard clean oven (vs. self clean), so unfortunately, you will have to use a can of Easy Off or similar oven cleaner.
May 07, 2009 | GE 24" Built-in Single Electric Wall Oven...
Oven will not heat to temperature setting
Dec 31, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
Wall Oven
Hello zultar777,
Good Luck
Regards,
Rick
Dec 04, 2008 | Maytag CWG3100A Gas Single Oven
Kenmore oven model # 79071053400
Check for a loose bulb or faulty door switch. Sometimes a bulb can fail and the filament can reconnect to work at a higher wattage before failing completely.
Jun 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
