Question about The Computers & Internet
What is the value of a MDC74570W - The Computers & Internet
Math mean median mode
The question is incomplete.
The mean, also called the average is defined as
mean= (sum of the data values)/(number of data elements)
Mode = the most frequent data value (the one that is most repeated)
To find the median:
  1. Order the data values in ascending order (sort them from the smallestr to the largest), and
  2. Locate the data value that is in the middle.
  3. If the number of data values id ODD (not a multiple of 2) there is only one middle element. That is the median.
  4. If the number of data elements is EVEN (multiple of 2), there is not one middle element but two.
  5. The median is the average of the two middle element values
    1. Median =( left of middle value +right of middle value)/2
    2. Imagine this median value to be inserted between the two middle elements
Example 1
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20)/9=?
Mode= most frequent value. Here it is 13 (repeated 3 times)
There are 9 values, an odd number. Middle element is the 5th ( 13.5)
Median=13.5
Example 2
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20, 25
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20 + 25)/10=?
There are 10 values, an even number. Middle element is not among the values. There are two middle elements (the 5th and the 6th) or
The value of the median is the average of the 5th and 6th elements or
Value of Median =(13.5+14)/2=?
Nov 21, 2013 | Computers & Internet
Tip
Change Thumbnail Size And Quality
If any of you out there like to use the thumbnail view, especially for browsing through photos and images, it can become a bit of a drain on your system. It is possible to lower the thumbnail size and quality by editing the following registry keys.
Open the registry and navigate to :
HKEY_CURRENT_USER\ Software\ Microsoft \ Windows\ CurrentVersion\ Explorer
Create a new DWORD value called ThumbnailSize, and set the value between 32 and 256.
And/or create another DWORD value called ThumbnailQuality, and set the value between 50 and 100.
Key Details :
USER Key: [HKEY_CURRENT_USER\ Software\ Microsoft \ Windows\ CurrentVersion\ Explorer]
Value Name: ThumbnailSize
Data Type: REG_DWORD (DWORD Value)
Data Value: 32 - 256
Value Name: ThumbnailQuality
Data Value: 50 - 100
let me know it's help to you
on Dec 04, 2009 | Computers & Internet
What is the book value of a suzuki 750 gsxr 1999/2002
1999 Suzuki GSXR750/Excellent Condition/Kelley Blue Book Value is $2,705.00 * 2002 Suzuki GSXR750/Excellent Condition/Kelley Blue Book Value is $3,570.00 * * Values are based on bike being in excellent condition, and are values quoted by Kelley Blue Book Motorcycles. These values are not guaranteed values.
Sep 16, 2013 | Suzuki GSX-R 750 Motorcycles
Can I calculate p-value on the casio fx-115es plus?
Press MODE 3 AC to enter the statistics mode. Press SHIFT STAT 7 to bring up the distribution menu then 1 to invoke P( .
Nov 03, 2012 | Casio FX-115ES Scientific Calculator
Future value
When you buy it is worth $60, 000
I will assume that at the end of a year it is the whole new value of the house that is increased by 5%.
After 1 year value=60,000*(1+0.05)^1
After 2 years value=$60,000(1+0.05)*(1+0.05)=60,000*(1.05)^2
Do you see the pattern?
After 7 years, the value of the house will be 60,000*(1.05)^7
However if the increase is not compounded
Then after 1 year value=60,000*(1+0.05)
After 2 years, value=60,000*(1+0.05+0.05)=60,000*(1+2*0.05)
After 7 years, value=60,000*(1+7*0.05)
Depending on the coumpounding or not the two values will be different
With compounding: final value=$84,426.02
Without compunding: final value is $81, 000.
I showed you the possible mathematical solutions. It is now up to you to decide which is the one that applies to your case.
Jan 28, 2012 | HP 10bII Calculator
About the place value and value
Place values
Here is a link that shows you the place values.
The value on the calculator is the same as those place values I gave you the link to. Just make sure you know where the decimal value is.
Jun 13, 2011 | Office Equipment & Supplies
Plz tell me Sir/Madam. what is Hlookup And give me example
Hi Geetad11
This is Horizontal lookup , used to look up value in a 2 dimensional table .It searches for a value in the top row of a table or an array of values, and then returns a value in the same column from a row you specify in the table or array. Use HLOOKUP when your comparison values are located in a row across the top of a table of data, and you want to look down a specified number of rows. The H in HLOOKUP stands for "Horizontal."
Formulae Syntax
HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)
Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string.
Table_array is a table of information in which data is looked up. Use a reference to a range or a range name.
  • The values in the first row of table_array can be text, numbers, or logical values.
  • If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted.
  • Uppercase and lowercase text are equivalent.
  • You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
Row_index_num is the row number in table_array from which the matching value will be returned. A row_index_num of 1 returns the first row value in table_array, a row_index_num of 2 returns the second row value in table_array, and so on. If row_index_num is less than 1, HLOOKUP returns the #VALUE! error value; if row_index_num is greater than the number of rows on table_array, HLOOKUP returns the #REF! error value.
Range_lookup is a logical value that specifies whether you want HLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, HLOOKUP will find an exact match. If one is not found, the error value #N/A is returned.
Remarks
  • If HLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than lookup_value.
  • If lookup_value is smaller than the smallest value in the first row of table_array, HLOOKUP returns the #N/A error value.
Example
The example may be easier to understand if you copy it to a blank worksheet.ramsoft.jpg
Oct 06, 2010 | Microsoft Excel for PC
What is the value of 3 in 53
in any decimal number each of the digits has two values
  • face value
  • place value
in 53 the face value as well as place value for 3 are 3
Thanks
Zulfikar ali
ali_zulfikar@yahoo.com
9899780221
Jan 30, 2009 | SoftMath Algebrator - Algebra Homework...
Function
VLOOKUP is to Searches for a value in the leftmost column of a table, and then returns a value in the same row from a column you specify in the table. Use VLOOKUP instead of HLOOKUP when your comparison values are located in a column to the left of the data you want to find. The V in VLOOKUP stands for "Vertical." Syntax VLOOKUP(lookup_value,table_array,col_index_num,range_lookup) Lookup_value is the value to be found in the first column of the array. Lookup_value can be a value, a reference, or a text string. Table_array is the table of information in which data is looked up. Use a reference to a range or a range name, such as Database or List. If range_lookup is TRUE, the values in the first column of table_array must be placed in ascending order: ..., -2, -1, 0, 1, 2, ..., A-Z, FALSE, TRUE; otherwise VLOOKUP may not give the correct value. If range_lookup is FALSE, table_array does not need to be sorted. You can put the values in ascending order by choosing the Sort command from the Data menu and selecting Ascending. The values in the first column of table_array can be text, numbers, or logical values. Uppercase and lowercase text are equivalent. Col_index_num is the column number in table_array from which the matching value must be returned. A col_index_num of 1 returns the value in the first column in table_array; a col_index_num of 2 returns the value in the second column in table_array, and so on. If col_index_num is less than 1, VLOOKUP returns the #VALUE! error value; if col_index_num is greater than the number of columns in table_array, VLOOKUP returns the #REF! error value. Range_lookup is a logical value that specifies whether you want VLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, VLOOKUP will find an exact match. If one is not found, the error value #N/A is returned. Remarks If VLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than or equal to lookup_value. If lookup_value is smaller than the smallest value in the first column of table_array, VLOOKUP returns the #N/A error value. If VLOOKUP can't find lookup_value, and range_lookup is FALSE, VLOOKUP returns the #N/A value.
Aug 30, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
