WHAT CAUSES ERROR CODE 1 ON PINNACLE 27 LAMINATOR?
3 Suggested Answers
alicantecoli
  • 22306 Answers
SOURCE: I have a Pinnacle 27
have no idea what the code means but i would hazard a guess and say the heater circuit isnt working ,take it apart and try a volt meter across the heater element
Posted on Dec 19, 2010
clintonmulti
  • 238 Answers
SOURCE: GBC Pinnacle 27. Right side top heat shoe does not get as hot as left side. Lamination is milky colored on right side
Could be one of the elimebts have burnt out as there are more than one into the tip just take to local shoe repiar as taking it to golf shop will be expensive
Posted on Sep 03, 2016
Sep 03, 2016 | Cars & Trucks
Our machine is starting to squeal when working what do we do
There isn't anything you can do, those machines are screamers. sometimes they start screaching right away, sometimes it takes a few rolls of film run through before they start, but they ALWAYS start to scream, sooner or later. it becomes loud enough that some people refuse to use it because they think its coming apart. not my favorite.
Sep 18, 2014 | Gbc Pinnacle 27 Ezload Roll Laminator, 27...
Pinnacle er-1
left hand side cover is probably off and excess light is getting onto the motor speed sensor. put the side cover back on and try it, most likely that will fix it. could also be the set screw on the right side is loose, error 1 means you have a speed problem. check gears and chain. only other part that has caused this in the past is the keypanel.
Sep 15, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Gbc pinnacle 27 ezload power light turns on but the front panel does not
you have one of the TCO's that is blown out, To test them you need to take the right side cover off, and test continuity from one side of the tco to the other, start with the tco wire that is connected to the tray switch, the other end of the tco wire is connected to the wire block on the right side of the laminator. just follow the wires back to the heat shoe and check for continuity. A TCO is no more than a temperature fuse. you can actually make a test "jumper wire" and jump across both connectors and it should power right on. You need to be careful and follow the wires back correctly so you don't fry the laminator the rest of the way.
Mar 31, 2014 | Office Equipment & Supplies
GBC Pinnacle27 Laminator has no control board power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......Westco Laminating Service 405-324-6092.
Jan 08, 2014 | GENERAL BINDING CORPORATION Laminating...
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
I have a Pinnacle 27 EZ load Laminator that keeps showing an ERROR CODE 02, nothing in my service manual showes me what this problem is, the unit will not run, HELP!
Dec 16, 2010 | Office Equipment & Supplies
I work for the city of red deer, and we just purchased the GBC Pinnacle 27" laminator. We keep getting an error code ( Er.1 ) it dosent list this code in the manuel. We have tried calling the 7 different...
That error is the speed sensor and it could be a bad sensor or light is getting into the machine and causing a hard time with the opticals in the sensor or it could be bad set screw, The transport system that moves the lamination holder is having issues. Check the chain and gears and make sure they are tight.
Dec 27, 2017 | Office Equipment & Supplies
42 people viewed this question
jasbo
jasbo
