Question about Cycling
I need a users manual for Baby Car 2-4 yr. old motorized bicycle model 80KB 803. Also need to know which battery charger?
SOURCE: user manual
I found a user manual from another website.
Posted on Jun 12, 2008
SOURCE: canon vm-e2e canovision 8 user manual, charger, adapter and battery
hi bert
i have the items you are looking for, but the manual is in dutch
my email: robuul@hotmail.com
grtz ronald
Posted on Jan 03, 2009
  • 990 Answers
SOURCE: Need users manual for old Schwinn Airdyne - analog model
Sheldon Brown's Bicycle glossery is a good place to start, you can google him and he may be slow on replys but he can usally steer you in the right direction.
Posted on Aug 21, 2009
Testimonial: "I emailed Sheldon Brown. Larry"
SOURCE: Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
Look behind the ceraminc logs chained to the burner frame. They are metal plates with instructions. That is how mine is.
I am looking to get new doors for this model, no luck looking online. Any ideas?
Posted on Mar 04, 2010
SOURCE: Have 36 volt club car w/coils
I DON'T HAVE HELP FOR THIS BUT.................WITH MINE THE RELAYS SEEM TO JUST CLICK. DOES FINE IN REVERSE BUT WILL NOT GO FORWARD. I DID GET A WIRING DIAGRAM BUT CAN NOT TELL FROM IT WHAT WOULD BE WRONG. WHAT ARE THE CONNECTIONS ON THE MOTOR. THERE ARE FOUR. WHAT IS WHAT THERE? THANK YOU TRACY
Posted on May 13, 2010
My 2 yr old Samsung tablet will not take a charge any more. What can I do?
I would start by replacing the charger. If it is completely dead you will need to use a wall charger to charge it. If that doesn't help then it may be the battery. You can check out iFixIt to see if they have a replacement battery for your model.
Jan 14, 2016 | Samsung Tablets & eReaders
Do you know where I could find a user guide manual for a NEXXTECH Ni-Cd/Ni-MH 2300033 battery charger?
Radio Shack 230-0033 appears to be the same charger.
I have this charger (Nexxtech branded, model 2300033) and the specs all appear to line up. However, I don't have the manual.
http://support.radioshack.com/support_electronics/71094.htm
Aug 23, 2012 | Cameras
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
Battery charger on green light when battery flat ,it should be on red also when charger plugged into bike, bike works ok when you take charger out bike stops working
If your bike works when you have the charger connected but doesn't whith the charger disconnected and just the battery then your battery is not charged or you have a bad connection between the battery and ebike.
If the battery charger is showing green then it normally means that charging has stopped charging and there is no current flow to battery. This could be because the battery is fully charged, OR there is an open circuit (broken wire, etc.) between the charger and battery, OR your battery is so flat the voltage is below the low voltage cut-off point of the charger so the charger is not switching on.
You need to check the voltage out of your battery and compare it to the LVC of your charger (should be specified in the user manual), but from what you have described I'd say you need to replace your battery.
Feb 27, 2011 | Electric Bicycle Motor, Bike,electric...
Need owners manual for pro mariner battery charger model ss 30 (1990) yr
NEED OWNERS MANUAL & PARTS LIST FOR PRO MARINER SS30 BATTERY CHARGER
Oct 31, 2009 | ProMariner Boating
Aug 21, 2009 | Cycling
Stolen adult bike has connector piece
Goto this place:
http://www.instep.net/Product/Accessories/Detail/82_Bicycle_Trailer_Coupler_25-SA074/
Nov 01, 2008 | InSTEP PF250 Bicycle Baby Bike/Biking...
Cycling Logo
37 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
