Question about Gaggenau Refrigerators
How do you adjust height of adjustable dispenser unit on Gaggenau CM 200610 built in coffee maker. The user manual says it is adjustable, but gives no instructions.
Just got an answer from Gaggenau customer service. You have to just push it up and down, harder than you would expect. The low point is for a very small cup. The high point will fit an average mug.
SOURCE: Dacor coffee maker
Welcome to the club of unhappy Dacor coffee machine owners. The problem you are having is the problem everyone has had. The only thing I can suggest that has worked most often for me is not leaving the machine on for very long. I think the temperature gets messed up if it is left on too long. I just use mine now for a few cups in the am and then I turn it off. I've been so frustrated with it that I have gone back to my french press. One of the posters on this site actually got Dacor to buy her machine back. I will probably try that route as well.She replaced it with a Meile and is very happy with it. Good luck!
Posted on Aug 09, 2008
SOURCE: Need Replacement pot for black Kit. Select. Dual Pot Coffee Maker CM-202
Select Brands
Kitchen Selectives
Select Brands
Customer Service Or Call 913-663-4500
To order replacement carafes for the CM-202 Dual Coffee Maker you have to call Customer Service at 913-663-4500 - This item cannot be ordered on line.
Posted on Jan 01, 2009
SOURCE: can't adjust 2004 Ford Expedition headlight
I had a similar problem on my 04 expedition. I just bought it and the headlights were aiming too far down. A rather larger gap was noticeable between the headlight and the hood. The so called adjustment bolt did nothing. I removed the headlights and found 2 issues. On the adjustment bolt there is a washer. Make sure when you re-install the headlight the washer sets on top of the plastic slot and is visible when looking down behind the headlight. Without the washer being in the correct location it will not tighten the headlight in place.
Second I found the adjustment bolt adjusted nothing. It merely tightened the headlight in place. What I had to do was to loosen this bolt and physically move the headlight into place and the re-tighten the bolt. Hence the slot is the adjustment. Turning the bolt CW or CCW did not move the headlight.
I tried several things trying to figure why the lights would not move until I realized I could move the light with my hands and tightened them in place using the adjustment bolt.
This may not be your issue but I found the owners manual instructions to be useless.
Posted on Jan 02, 2009
SOURCE: Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Posted on Jan 06, 2009
SOURCE: operating instructions
I have this manual (CM500) and can scan/email it to you if you send me your email address...also I am looking for a replacement lid for my carafe for this machine if anyone is looking to get rid of theirs!
Posted on Feb 20, 2009
Water puring out underneath Gaggenau coffee machine
The water in unit is fed via a hose to the heating element. If the hose is broken or disconnected the water never reaches the element and spills out the bottom nice and cold.
If you remove the bottom panel the problem will be instantly obvious.
OR put water in unit and see where it comes out of!!!!!!!!!
Aug 30, 2015 | Gaggenau CM 200-630 Aluminum Espresso...
Beans not ground completely
Hello Jeanie Henderson,
Quite an impressive wall mount... (not in-expensive
(I would EXPECT you'd get a better response)).
((( I am absolutely positive there is one... )))
Thermador is ONE of the WORLD's top manufacturers...
of PROUDLY PREMIUM equipment .
Evidently it sells under different names... Since we are
open to GLOBAL questions ... I searched for your
MODEL NUMBER (as they say in Australia... "no joy").
Currently sold (in USA) as...
Gaggenau Thermador CM210710... seems to resonate
for parts... As to LABOR... It sounds as though you are
willing... (and able (possibly a lucrative career))...
Your representative's response is QUITE DISAPOINTING
... I imagine if Executives heard... a FRANCHISE COULD
BE IN GREAT PERIL... (let THERMADOR know ...
(it helps them)).
USA Customer contact page:
https://secure.gaggenau.com/us/support/helpdesk
Keep escalating until your coffee is served...!!
  • Customer service: +1 800-735-4328
  • Founded: 1916
  • CEO: Michael Traub
I spotted a grinder set on eBay... but I personally don't
think you should have to get TOP END PREMIUM
THERMADOR parts yourself...!!
THERMADOR is a great company... I am confident
you only need to find a sympathetic ear.
Comment me back... I'm here daily
(I restored one of the first HOBART electric grinders
ever made... Red with gold & black trim and a giant
ALUMINUM hopper on the top (about 3 feet tall
(the grinder burrs were completely ADJUSTABLE
and only needed to be cleaned... Then gave it away))).
((((but YOU shouldn't have to do it )))).
Carnac the Magnificent
I personally DO NOT recommend SEARS
(personal bad experiences... used to be a fan)
BUT... Lookie here:
http://www.sears.com/gaggenau-cm210710-gag-24inch-bi-coffee-machine-ss/p-A014177046?redirectType=SKIP_LEVEL#
Feb 11, 2018 | Gaggenau CM 200-630 Aluminum Espresso...
At first my Miele CM5000 worked perfectly. When I pressed the espresso button, a perfect espresso would come out- the machine dispensed the correct amount of liquid then stopped automatically. Now, the...
If the espresso coffee outputs too much water and doesn't stop, there is an easy fix. The quantity adjustment for the machine is off. After looking through the user manual, I found out that you could press and hold the espresso button, and then follow the on-screen instructions where you can specify the quantity poured.
Aug 03, 2013 | Miele Cm 5000
Does not dispense enough water. I get about 2 ounces of coffee at a time. How do I adjust the water level?
When was the last time the unit was descaled? A build up of scale will gradually restrict and then stop the water flow.
Feb 02, 2010 | Keurig B100 Coffee Maker
Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Jul 02, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Where to find a dispenser holder for Gaggia Syncrony logic
Need also to find height adjustable coffee dispenser, also need measuring scoop,brush and coffee dispenser with wrench.
Apr 25, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Refrigerators Logo
29 people viewed this question
Top Gaggenau Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Gaggenau Refrigerator Expert? Answer questions, earn points and help others
