Question about The Computers & Internet
How do I get names to come when I press the plus sign it says no results found
  • The Master
  • 1,830 Answers
Be specific. What are you trying to get names from?
Posted on May 12, 2017
Which button i need to use for click button percentage... example 45 + 10%
The percentage sign is the equal sign. Press Shift and =.
However 10% is really 0.10, so it will be easier to work with since using the % usually results in syntax errors.
Dec 14, 2010 | Casio FX-115MS Plus Calculator
Tip
How to use multiple login on a single yahoo messanger
  1. Go to start > Run > Type regedit > Press Enter
  2. Click on the plus sign near the folder HKEY_CURRENT_USER
  3. Click on the plus sign near the folder Software
  4. Click on the plus sign near the folder Yahoo
  5. Click on the plus sign near the folder Pager
  6. Right Click on the folder name Test > New > DWORD Value
  7. Right side you will get a file named New Value #1
  8. Right Click on the file New Value #1 and Rename it as Plural and press enter
  9. Double Click on the file Plural
  10. You will get a windown named Edit DWORD Value
  11. Type 1 inside 'Select the Value data' and press enter
  12. Close the registery editor window
  13. Now you can launch multiple windows and use different ID's.
on Feb 01, 2010 | Computers & Internet
My computer will not recognize the dvd1260i burner
These are the steps to resolve the issue for the cd/dvd icon missing in the My computer.
Step 1: Please perform manual registry set up by following the below steps:
Please make a full backup of your registry files, particularly user.dat, system.dat, and policy.pol. If you make any incorrect entries, the backed-up registry files can be used to replace the corrupted registry entries.
Follow these steps to backup registry:
1. Click Start, select Run. In the "Open" field type REGEDIT
2. Click OK and click "File" in the menu bar
3. Click "Export" from the drop down menu this will open a new box
4. Click the down arrow beside "Save In" and select "Local Disk (C:)"
5. In the File Name field type BACKUP.REG Verify that under the "Export Range", that the radio button is beside "All"
6. Click Save.
Now make the following changes in registry:
1. Click Start and click Run(XP) or type Click Start and type regedit in search then hit enter(vista, Windows 7).
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor.
Step 2: Please uninstall the CD/DVD drive form Device Manager :
1. Click Start and select Control Panel.
2. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
3. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
4. Click the Hardware tab and then click the Device Manager button.
5. Click the plus (+) sign next to the DVD/CD-ROM drives .
6. Right-click the driver listed under this Category and select Uninstall. In the Confirm Device Removal dialog box, click OK.
7. Repeat step 6 until all entries under the device category are deleted.
8. Restart the computer.
After the notebook is restarted it automatically detects the drive and the drivers are installed.
Regards,
Shami
Oct 31, 2010 | HP DVD1260i DVDRAM Burner
TSST Corp CDRW/DVD TSL462D ATA Device (code 10) will not start up.
Please perform the below steps to fix the issue:
6. Click Save.
method.
Regards,
Shami
Oct 04, 2010 | Computers & Internet
The cdrw/dvd drive has dissappeared after an update from microsoft. after trying to reinstall the drivers it still isnt showing up in my computer.could the upper and lower filters in the registry be...
Please follow the steps below to resolve the issue if you are not comfortable doing this then just take help from any friend or neighbour if this did not resolve the issue then replace the drive asap because it is a hardware issue.
1. Press Windows Key+R and type regedit in the text box and click OK
2. Click "File" in the menu.
3. Click "Export" from the drop-down menu.
4. Click the down arrow beside "Save In" and select Local Disk
(C.
5. Type Backup.reg in the File Name field.
6. Click Save.
=== Deleting UpperFilter and LowerFilter Registry Keys ===
1. Click Start and click Run.
and click it.
better
right
method.
right
15. Quit the Registry Editor and restart the computer.
CD/DVD drivers reinstall:
Press the Windows Key + R and type devmgmt.msc and press enter.
Device manager will open up.
Click the + sign beside DVD/CD Drives.
Right Click on the device listed under it and select Uninstall
Restart the PC and let the driver install automatically.
Check the issue once again.
Jul 30, 2010 | Dell OptiPlex GX620 PC Desktop
Error 19
Hi
You can try the following steps to resolve the Code 19 issue.
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Jul 16, 2010 | Sony Optiarc AD-7240S 24x DVDRW DL SATA...
After changing my motherboard, the Dell no longer recognized the CDDVD RW drive. In fact, it now shows up as a floppy disk drive. I flashed the BIOS and that did not help.
(C.
6. Click Save.
and click it.
better
right
method.
right
Mar 13, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
I cant burn a cd in itunes when i try to burn a cd it says " the registry settings used by the itunes drivers for importing and burning cds and dvds are missing. this can happen as a result of installing...
    1. On the Start menu, click Run.
    2. Type regedit and click OK.
    3. Click the plus sign next to HKEY_LOCAL_MACHINE to expand the tree.
    4. Click the plus sign next to SYSTEM.
    5. Click the plus sign next to CurrentControlSet.
    6. Click the plus sign next to Control.
    7. Click the plus sign next to Class.
    8. Click to select the heading that begins {4D36E965- (don't click the plus sign here).
      It should look like this: ts2372_1.jpg
    10. In the dialog box that opens, make sure the "Selected branch" radio button is selected and save the file somewhere that you can find it.
    11. Right-click the LowerFilters key and from the shortcut menu, click Delete. Note: If you don't see a LowerFilters key then continue to the next step.
    12. If you see the UpperFilters entry right click on it and click Modify. Go to step 16. NB.If you don't see UpperFilters go to step 13.
    13. NB. If you don't see an UpperFilters entry you have to add it back in. Do step 14 and 15 to correct this.
    14. Right click on the right side of the screen and select New.
    15. Select Multi-String Value and name it UpperFilters. Go back to step 12.
    16. Select the entire contents of the text in the Value data text field.
    17. Right-click the selected text and from the shortcut menu, click Cut.
    18. Type GEARAspiWDM and press Return. Pressing Return adds a carriage return in the field and is important.
    19. Click OK.
    20. Restart the computer.
Dec 03, 2009 | HP Computers & Internet
How do I ente 8x - 1 over 10 on my TI 84 plus silve edition
I am not sure what the cross (x) means: is it a multiplication or the variable x, so I took a screen capture of both cases.
The top case is obtained as follows the asterisk is the multiplication sign to thr right of digit 9; the small minus is the change sign key the minus sign in parentheses under digit 3 and to the left of ENTER key.; the forward slash is the division sign, above the multiplication sign.
This small minus called change sign makes a positive number negative and a negative number positive, hence its name. If your expression starts with a negative sign that is the one to use. Use it also for negative exponents.
As you can see the result is -.8. Notice how the - before the dot is small with respect to the regular minus, as in the last expression.
For the last expression on the screen capture, there is nothing special, except that you have two ways to enter the variable X.
1. Press [ALPHA] [STO->]
2. Press the key [X,T, Theta, n] to the right of the green [ALPHA] key.
Hope it helps.
If x is the multiplication sign
8[x] [(] (-)1
Oct 06, 2009 | Texas Instruments TI-84 Plus Calculator
Optiarc ad 7530a dvd rw drive
I have seen this problem many times. 99% of the time this will fix it for you. The first part of this fix is to backup the current registry just in case you need to go back.
Try this. I really think it will fix your problem :)
1. Click Start.
2. Click Run.
4. Click OK.
10. Click Save.
Restart your Computer in order for the registry - fix to work.
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
