Question about Hardware & Accessories
What operation shud I have on for my timer to stay on at all times
  • 923 Answers
What kind of timer, made by what company, what model, and what is the reason you want to defeat the intent of the timer?
Posted on May 12, 2017
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
I have a powerbar with 8 outlets 4 always on 4 controled by a digital timer with 6 buttons, Top row Day, Hour, Min. Bottom row Clk, Mode, Prg. When i set the timers my lights dont shut off or correlate to...
1) Copy following link to identify timer and download manual:
2) Check that battery is operable,
Move selector switch to ON position.
Check that each program has ON and OFF times set.
Check that each ON time has same days of operation as OFF time.
To delete programs, hold down MODE button and press Prog button.
Check outlet has correct polarity using circuit analyzer.
Try power strip on different outlet.
Check load rating of timer matches type of load being controlled.
This timer might not work for CFL inductive loads, try with ordinary light bulb.
Dec 28, 2012 | Globe Electric Hardware & Accessories
I bought the ge digital heavy duty timer Model#15079 I want to use it for my saltwater tank where a light stays on from 7 am to 9 pm an another light stays on from 2 pm until 8pm is this possible with this...
Easiest solution is to buy two separate timers.
GE does not have 2 channel plug-in timer. Nor does Woods, UPM, Swilight, Sylvania, Tork, etc etc.
Zilla has a two channel power strip where one channel is for 12 daytime hours and 1 channel for 12 nighttime hours. The yellow outlets power daytime hours and blue for nighttime. You can adjust current time so the hours can be whatever, but the 2 channels are strictly 12 hours each and do not overlap
Your time schedule doesn't fit zilla
You need a 2-channel timer which takes you into more expensive territory ($150-$300), or just buy two separate timers since each load has to operate independently.
Intermatic make 2 and 4 channel timer:
Apr 13, 2011 | Jasco 15079 SevenDay TwoOutlet Digital...
Dishwasher will not drain
Most of these will either be draining all the time or not draining because of the open or close position of the plunger that controls the draining,When timer go,s bad it still times and turns but not on time,when it stays draining for 90 seconds and and stays draining after it should have shut off ,,well it burns out and freezes that plunger that operates the draining of the dishwasher.Thus both timer and control plunger need replaced,,over a 100 dollars in parts,GET A NEW DISHWASHER
May 12, 2010 | GE Nautilus 24" Built-in Dishwasher
Usb led stayes on after shut down
the connection of ur led is probably coming from the cell of ur mother board that stays active for real time clock systems. i suggest u shud remove ur usb in such a case as it might use up all ur cell if stayed connected ....
Feb 08, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Moniter stays in powersaving mode 75% of time.
Ther shud be a STANDBY / POWER button on your keyboard..Press it, then your monitor will be back to normal..
ask for any further assistance...
Jun 11, 2009 | Dell Dimension 3100 PC Desktop
Default paper option
You can try to do these steps >>
click on start > control panel > printer n faxes > right click properties > print a test page > see if it prints in a correct format .
in case it doesnot >
delete the printer icon > from printer n faxes .
unplug the usb cable > go to device manager > uninstall imaging devices > restart the computer .
plug in the usb cable > u shud see found new hardware wizard > follow the steps n install teh basic drviers once again.
It shud be working .
Take care n thanks !!
Oct 31, 2008 | HP Officejet 5610 All-In-One InkJet...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
