Question about The Kitchen Appliances - Others
My deep fryer fire came down to the jeeklore - The Kitchen Appliances - Others
SOURCE: Rival CFZ530 Deep fryer
I had this same problem which is how I came across your post, and I found on the Rival website ( www.rivalproducts.com ) you can email the company and tell them the model number and they will email you the manual, and if you're like me and hate to wait that long, you can call their customer service number and tell them what you need and they will email you the manual in about an hour. The number the website gave me was  1-800-323-9519, and I also realized there was also a number on the box too.
Posted on Apr 16, 2008
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Posted on Aug 05, 2008
Sheikhtijani
  • 1284 Answers
SOURCE: delonghi deep fryer drain tube replacement
Hi, go through the operating manual of the deep fryer on the link below to learn how to replace the drain tube...
http://www.delonghi.co.uk/pdf_files/F350WA.pdf
Take care
Posted on Jun 01, 2010
kebah
  • 683 Answers
SOURCE: pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Posted on Sep 13, 2011
SOURCE: Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Posted on Apr 27, 2013
Deep fryer ignites but burner flames will not enter cylinders
Hi there.
Fire tubes may be clogged with soot. Have a technician inspect and clean the fire tubes for soot deposits/ build ups.
Check also if there is no air or ventilation directed on flue as it will push the flames back to the burners.
Regards.
Aug 12, 2013 | DCS Gas Deep Fryer 40 Lbs Double Basket...
Imperial gas fryer burner wont light
Check out the over heat is not shutting down to soon or thermostat is not opening ,
Sep 01, 2012 | Imperial IFS40 Deep Fryer
Pitco deep fryer flames coming out the fryer
Hi there.
Regards.
Sep 12, 2011 | Pitco Frialator SG14 Deep Fryer
Fryer does not shut off when temp .is reached
I assume it is a gas model. There are 2 thermostats. One is adjustable, you set your temp, it sounds like it has gone bad.. The second thermostat is the high limit thermostat. When it reaches 450 degrees F, it will shut down the pilot and main flame to prevent a grease fire. It may be possible that someone has hooked the thermostat up wrong. Next time you fire it up, disconnect one of the thermostat wires that has the temperature knob. If the flame goes out, the thermostat is bad,
Oct 04, 2010 | Imperial IFS40 Deep Fryer
What do I need to buy to properly vent a 40 lb. deep fryer?
Well, these are commercial fryers that are typically under a commercial exhaust hood with a fire suppression nozzle located directly above them. Why, are you doing something out of the ordinary?
Oct 29, 2009 | Cecilware FMS-40 Deep Fryer
Fryer wont fire up
Check the continuity, flip the switch on and off using an ohmmeter, if the switch is ok, check the thermal fuse inside.(you have to open the unit) replace whatever is defective
Jun 28, 2009 | Pitco Frialator SG14 Deep Fryer
My deep fryers got on fire hS ALOT BLACK
leaking pan
safety thermostat fail and main thermostat fail and cause flash over.
Jun 22, 2009 | Pitco Frialator SG14 Deep Fryer
Oil drip
Here you go
http://www.frymaster.com/?xhtml=xhtml/fry/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
You will need to use the 1st drop down to select service manual.
Use the 2nd drop down to select MJ45 series fryers.
Thanks
Aug 19, 2008 | Frymaster Dean MJ45EMSD Deep Fryer
Adcraft double deep fryer
its safety switch not functioning
Jul 03, 2008 | Adcraft DF-6L/2 Deep Fryer
Kitchen Appliances - Others Logo
29 people viewed this question
Top Kitchen Appliances - Others Experts
Brenda Landram-Pope
Bilral
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
