Printer has worked perfectly until now when it will not print black text from documents. Prints color headings.
  • 4 more comments
  • chrismac36 Jul 25, 2009
    I have replaced the black ink cartridge
    Brother MFC-790cw
    I have done everything. Cleaned heads, printed test patterns, colors are good, no black test print.
    Changed black cartridge although it was nowhere near empty.
    Unplugged and plugged everything back in
    Chris
    Mac OS 10.4. as I say the printer has worked perfectly until now.
    I think the black ink nozzle is plugged I have cleaned the black cartridge head so many times, even went and bought a new cartridge . Still no black test pattern.
    I have a bunch of stuff to print out. This is getting a real pain.
    Chris
  • chrismac36 Jul 26, 2009
    Yes! I hooked up my Canon and it worked perfectly.
    Chris
  • chrismac36 Aug 01, 2009
    I have progressed to to point where I can see the problem is that the black ink is, for some reason blocked on the printer itself because I can test prints of every other color except black. I cleaned the black printer head so many times I had to buy a new one, it still will not print black.
    Thanks for your suggestions. If you can tell me how to clean the ink inlet on the printer I will be very thankful.
    Chris
    President:
  • 3,278 Answers
Have you replaced any cartridges ? If not, my suggestion would be to replace the black cartridge. Hope this helps.
Posted on Aug 01, 2009
  • 1 more comment
  • NinaE Aug 01, 2009
    Sorry ... I didn't see the other suggestions. What printer are you using ???
    If Lexmark printer, be certain that the printhead wire harness is fully seated and properly aligned. Since you have gone through general troubleshooting, your printer may need servicing which may not be cost-effective. Alternatively, choose a very dark color, instead of black as your default.
    Sorry, Chris for not reading all the details of your comments. You mentioned that you cleaned the printheads. But, there is a certain procedure to clean the printheads for your printer:
    There is a button that says ink on the front panel of the
    printer.
    Hit it and scroll through the option until you see one that says
    clean the nozzles or print head.
    Hit OK
    Do this several times. Hope this resolves your problem.
    Also, set your printer to print with the black ink cartridge Only if you have already followed the above procedure several times.
  • 1,272 Answers
Can we have the manufacturer and model number of the printer and the operating system installed on the concerned computer.
Posted on Jul 25, 2009
  • 2 more comments
  • Anand Gupta
    Anand Gupta Jul 25, 2009
    It seems to be an issue with the printer software on your computer. Try installing the printr on another computer and check if you are able to print black text from the documents.
    Regards
    Anand
  • Anand Gupta
    Did you try printing through another computer? Try that and let me know.
  • Anand Gupta
    Anand Gupta Jul 26, 2009
    Well! Did you try connecing this printer to another computer and then tried printing through it. I understand that the Cannon works. However, the issue might be with the software of the printer itself.
    Regards
    Anand
  • Anand Gupta
    Anand Gupta Aug 01, 2009
    Has the issue reloved? If not, then let me know so that we can work for a solution.
Hi there
You may be out of blank ink. Please check if this is the case. There may be flashing lights on the printer itself indicating empty black ink.
If you're unsure, let me know the make and model of the printer.
Thanks.
  • Anonymous Jul 25, 2009
    Please let me know the brand and model ofprinter. Are you able to perform a head clean? If you're unsure let me know. Than ks,
Erratic black fusing
I'm not real sure about how the software separates the colors, but I believe there's a way to choose a color as all colors combined to make black, or simple black.
I'm not sure if I'm making any sense, but if the printer is using all the colors to layer up and make black, then it would be a pretty thick coating and that might cause it to flake off.
Oct 30, 2007 | Xerox Phaser 7700 Laser Printer
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
IP5000 3ebk problems
I had a similar problem. Pages in blue, but nozzle check in black. Tried what you tried. Changed the ink ($). Still no change. Then tried the maintenance option to clean the bottom plate. And now it is working. Go figure.
Apr 08, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Prints only color ink nothing in black
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Black text d not print
If the printer has been left for some weeks with an empty black cartridge then I suspect the print head is clogged.
To clean the print head, firstly remove it.
Remove each cartridge quickly and turn it upside down so ink does not drip out.
Flush warm water with a drop of detergent through the metal meshes at the bottom front inside of the print head unit. Continue untill the water coming out of the bottom of the print head is clear.
Then flush through with clean warm water for about 30secs.
Shake as much water as possible out of the unit.
Replace the cartridges quickly to avoid ink dripping out.
Undertake a nossle (head) clean on the printer until printing correctly.
Hope this helps.
Jul 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Black cartridge problem
Hi , good day , try to do head cleaning until the black print will appear perfect in color.
May 05, 2008 | Epson Stylus Color 460 InkJet Printer
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
