Question about Tablets & eReaders
How do I reset my tablet when I cannot turn it on ?
How long do the screen turn on after I reset it
Cannot get Wopad to turn on sometimes ' Android Tablet Forum
www.androidtablets.net > ... > Rockchip RK2818 Tablets
Dec 28, 2010 - 11 posts - ‎9 authors
It would do this in seconds. the screen would just turn black, like it does when you tap the .... Hi do you know hw to reset the wopad and how to eliminate this *process ...Now I can always turn it on, even after a long standby.
reset nabi 2 tablet if pattern lock forgotten? - Android Forums at ...
forums.androidcentral.com/...tablets/248800-reset-nabi-2-tablet-if-patter...
Jan 31, 2013 - 9 posts - ‎8 authors
How do you factory reset the nabi tablet 2? My child put ... Turn off your Nabi (To turnoff Press and hold the Power button for 3 seconds) then tap OK 2. Press the ... From your screen press the Volume ? (Low/Down) then the Volume + (Up) button. 5. Press the .... These Before & After Couple Photos Just M..
Dec 25, 2015 | Easy Wopad 7 inch Google Android 2.1...
HOW DO I RESET MY PATTERN LOCK ON MY TABLET
You will have to reset your tablet and then re-establish your pattern lock. To reset your tablet, turn the tablet off. Press and hold the Power and Volume (+) buttons until the tablet restarts. Let it finish it's reset cycle, and you can then use your tablet.
Mar 05, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
How do I get my CMP759 TABLET to stop loading? I tried resetting it several times and it turns off. When I turn it back on it will only stay in the loading stage.
I don't know much about these, but my husband uses tablets and says there might be a hard reset. Sometimes a very tiny button that is reset somewhere.
Dec 31, 2014 | Tablets & eReaders
I turn on my zeki 7' dual core tablet and it turns on but stays on the zeki logo screen and wont load..
Go to this site for the instructions on how to do a hard reset on your tablet.
http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
Dec 31, 2014 | Zeki Berk Ulu TBDG773B 7" 8 GB Black...
Why won't my kurio4s go to home page
YOU HAVE TO RESET TO FACTORY SETTINGS !! TRY THIS:
How to Factory Reset Kurio 4s Tablet
Hard resetting is other name of Factoryresetting. It will be the only option for thosewho want to format the tablet. It has to be performed when there is no other option to boot the tablet. Through this procedure, user can wipe off all the files i.e. data stored on the tablet. Along with the data, the malicious programs which are making the tablet to hang will also be wiped off. So the tablet would be afresh and will be new to use.
Kurio 7 tablet can also be reset as like any other tablet. This tablet runs on Androidoperating system and hence the procedureof resetting this tablet is similar to that ofresetting any other Android tablet. When you want to reset this tablet, you have to hold the power button to turn off the device. Now you have to turn on the device by holding the power button and also the volume up button simultaneously. When you hold these two buttons simultaneously, you will be able to get a new menu. In this menu, there will be option for resetting the tablet.
You have to select this option for resetting the tablet. This will ask you whether you want to confirm the reset of the tablet or not. If you confirm it, the data stored on the tablet will be wiped off and the tablet gets formatted. Now, the tablet will reboot automatically. After the reboot, you can notice that your tablet will be afresh and will be similar to the time when you have purchased it.
Make sure to take proper backup of the data present on the tablet before you chose the option of factory resetting or hard resetting. Take a copy of all the files in to memory card and remove it before resetting. In some tablets, there will be option of backup of files through syncing. If your tablet is having such feature, make use of it to ensure the safety of data.
Aug 04, 2014 | Tablets & eReaders
How do I unlock my trio tablet! The code is a pattern and the tablet doesnt give me an option to retrieve the pattern or even reset it. Please help! Thx Kat
Some tablets will prompt you to reset after you have tried and failed entering the correct password a certain number of times. You can try this, it could work too.
Jun 26, 2014 | Tablets & eReaders
Gmailkluunlock
You can reset your tablet to the original setting but it will delete all applications, Videos, Files and any other stuff that you have in the tablets internal storage
You can reset the tablet by using a paper clip to poke the reset hole for 1 minute while the tablet is turned on.
The reset button is located on the side of the tablet, this will reset the system and restart it self and you would notice that all other apps will no longer be there.
The second option is to access the recovery menu on your tablet to reset the system. Again, all applications and any files in the internal storage will be deleted.
To reset:
1. Turn off tablet
2. Press and hold Volume up and power at least 30 seconds to get the menu up,
3. Keep poking the hole to get in to the Wipe data and factory reset then press power to select
4. Once the it process the request, go back to the previous menu and select on restart for the device will power cycle.
Jun 05, 2014 | Curtis International KLU LT7028 Android...
Coby not working
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
May 28, 2014 | Coby Tablets & eReaders
I need to reset my kurio 4s
to reset this tablet, you have to hold the power button to turn off the device. Now you have to turn on the device by holding the power button and also the volume up button simultaneously. When you hold these two buttons simultaneously, you will be able to get a new menu. In this menu, there will be option for resetting the tablet. You have to select this option for resetting the tablet. This will ask you whether you want to confirm the reset of the tablet or not. If you confirm it, the data stored on the tablet will be wiped off and the tablet gets formatted. Now, the tablet will reboot automatically. After the reboot, you can notice that your tablet will be afresh and will be similar to the time when you have purchased it.
Nov 03, 2013 | Techno Source Kurio Kids Tablet With...
Tablets & eReaders Logo
26 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
