Question about Kenmore 24032\24036 Top Load Washer
I have a 80 series 110.2188400 that the spin clutch is screaming
It will agitate but when it goes to spin it will drain but the basket does not turn and makes a metal on metal noise. i need a repair manuel free and downloadable
  • 636 Answers
Try manuals online
Posted on Jul 25, 2009
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Hello, I have a series 80 washer. I replaced the coupling and the washer spins and drains but doesn't agitate. The agitator cogs seem fine. The timer hums and I smell a burning oder. Timer or clutch? HELP!
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
(The clutch is only used during the spin mode)
The first unfortunately is the motor. Kenmore / Whirlpool top load direct drive washers use a reversing motor.
When in agitate mode, the motor turn one way, When in spin mode it turns the other way for draining and spinning.
I'd check the following first before assuming that it's the motor though.
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I'd also look at the troubleshooting section of the manual.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight gear oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
Dec 12, 2010 | Kenmore Washing Machines
MY WHIRLPOOL LSQ8200PQ4 FILLS WASHES AND DRAINS
From what you state i would think that the brushes in the motor need replacement, as when worn the first thing that stops working is the spin cycle, The motor goes very weak, they tend to last between 3 an 5 years depending on how many washes your m/c has done, they will be of low cost and worth trying as it is an easy 30min fix for a handyperson...
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Won't advance to spin
You will need to replace the timer. Let me explain why;
After the agitation cycle, the machine will enter a drain mode where the basket will not spin, only drain. After some time, the timer should 'pause' causing the machine to engage the spin clutch. The timer contact has become stuck, not allowing the pause, thus never entering engaging the spin clutch.
Jul 02, 2008 | Washing Machines
Kenmore 70 Series Washer Spin Cycle Only issue.
It sounds like one of two things 1,A worn clutch .or 2.motor coupler is about gone,
May 20, 2008 | Kenmore 24032\24036 Top Load Washer
Won't Spin Without Assistance
It sounds to me like either there is an excessively heavy load in the washer and the unit simply isn't strong enough to get it going, or more likely the clutch mechanism/gearbox is malfunctioning. They use a clutch mechanism to allow the motor to run at a constant speed while the basket can start rotating slowly and pick up speed with time. If this clutch mechanism or gearbox isn't performing properly, the basket won't spin. It's not your motor or safety circuit since the basket will turn if given a little push.
Mar 10, 2008 | Washing Machines
Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Nov 05, 2007 | GE WSM2700D Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
465 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
