Question about Craftsman Garden
Have Craftsman 6.75 lawn mower, briggs Stratton engine. How do I adjust running speed ??
  • 923 Answers
Are you familiar with governor speed regulators on engines? There is a flap on a hinge under the flywheel cover which is moved by the air fins on the flywheel, which tries to close the throttle. There is also a spring that tries to open (increase) the throttle. So it's a contest between those two opposing forces! Increase the spring tension, and you will have more speed. But don't overdo it, or you could blow your engine! Good luck!
Posted on May 12, 2017
How to adjust governor
Yes, you can but the speed should be set with a tachometer. Your local dealer can make this adjustment for you.
Jun 28, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Where is primer on craftsman platinum push mower
It may not have one. Some mowers auto choke using spring tension on the choke plate in the carb. They open the choke when the engine speeds up after starting.
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
How do you control idle
This sounds like a governor problem, try moving the governor back and forth,l
Apr 17, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
I can push the handle all the way in, but I get very little speed from the mower.
Your throttle cable likely needs adjusting.
It should be fastened on the engine with a screw. Loosen that screw and adjust while engine is running then tighten Keep fingers away from underneath while engine is running.
Oct 05, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
