Question about Philips Televison & Video
What other t-con board will work for philips 46pfl8686k/02
Is the problem on my PHILIPS TV T-CON?
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 28, 2016 | Philips Televison & Video
I have a 47 Philips flat screen model #47pfl5708/f7 . the screen went dark when I turned it on. It flickers a little but nothing shows up I was wondering if it was the main board or the t-con board?
It is possible, the T-con board does produce the image you see but trying to fix this by guessing is a really bad idea. I would just buy a new TV and avoid the chance you are not correct about defectivethe part.
Oct 20, 2016 | Philips Televison & Video
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
www.electro-medical.blogspot.com
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Jan 19, 2015 | Polaroid 3211TLXB 32 in. LCD Television
I have a Philips Model 47FL7422D/37 the left side of the screen is darker than the right side and I can not adjust it. What is the problem.
Scrren problems can be a bad screen or a bad t-con board. The only way to check wich one is by trading out the T-con board, If the problem goes away it was the T-con board if it does not it's your screen. To find the part you have to get the part number from the actual part. you can order parts for this TV at www.interliquidparts.com
Jun 13, 2011 | Philips 47PFL7422D/37 Television
When i turn on the tv, the PHILIPS image is on Bright then the image is dark, you can barely tell that its on
This problems is the causes of the T-CON decoders board is dying.This T-CON decoders board sit at the bottom right in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Nov 26, 2010 | Philips 52PFL3603D/27 52 in. LCD HDTV
Philips 32mf231d - back light working, green power LED, no OSD or video - any common problems: i.e. bad cap in PS?
If you are getting backlight on and you can see glow on the sceen in darkened room, then the problem can be the T-CON board (blown fuse) or the main board is not sending the 12vdc or the signals (you need the scope and service manual to verify these signals) to the T-CON board. Look at the T-CON board fuse and voltage first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 17, 2010 | Philips 32MF231D Television
Televison & Video Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
