Question about Philips Televison & Video
My TV sound work but no image. first of all what could be the problem and where can I get the T-con board for my TV model and lastly, is there a way I can repair the board?
My TV sounds work perfectly but the image sometimes comes for few minutes and goes. sometimes the image freeze and other times too no image at all.the TV is Philips 46PFL8686k/02.I try looking for the t-con board for my TV model but cannot get it
SOURCE: TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Posted on Oct 31, 2007
  • 39 Answers
SOURCE: my rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Posted on Oct 02, 2008
  • 53 Answers
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Posted on Apr 30, 2009
  • 10515 Answers
SOURCE: Need a small sound board for my Samsung TV
If the sound is distorted, then you need to replace Sound board. If you do not have picture and sound, it has nothing to do with sound board.
There might be millions of reason and depends on the make and model of the TV.
On most of the samsung TV's, such problem might be due to defective Circuit Board. It can be replaced or repaired.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 07, 2009
SOURCE: Sanyo DP32649 works fine for a few minute, then
I have the exact same problem. It's a volume control issue. For me, when I turn my TV on and have it on low volume, it works fine (but sounds somewhat distorted). But once I turn the volume up to normal levels, the speakers crackle and then go out. I opened my tv and checked my speakers, and they were perfectly fine; not blown or anything. As well, the audio processor and circuitry didn't appear burned at all.
This used happened every few months for 30min or and hour at a time. Then, about 2 months ago, it happened again, and ever since then it still hasn't worked properly. The only way I got around this was by buying a cheap 2.1 speaker system, and connecting it to the audio output on the TV. Or you could buy a speaker bar or home theater system. I believe this issue has to do with problems with the circuitry in the audio amplifier, and there's not much you can do except add external speakers, or contact Sanyo if you still have an active warranty.
Depending on where you bought your TV (such as from walmart), its possible that the LCD panel was produced by Sanyo, but the electronics were done in China. Walmart does this with nearly every TV they sell.
Posted on Feb 21, 2010
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
Sound but no image on Hitachi 42pd5000
Two things need to be checked. The ballast board and the T-con board. Shine a flashlight on the screen with the TV on...If you see a faint picture moving, then the T-Con board is OK. The ballast board for the white backlight is bad. If you don't see a faint picture, then the T-con board is bad. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
May 23, 2017 | Hitachi Televison & Video
Jimmy shop.ccom has T-con board part #T500HVD0.0 500t10-C02 at the bottom in the description it list model PLDED5030A CRk my model is PLDED5066A-E since the parts # the same will it work in my tv?
If you see an image with a flashlight the T con board and power supply board are good. The back light controller board is the culprit.
Dec 18, 2015 | Televison & Video
I have a Samsung TV model UN50H6350AFXZA which has sound but no picture. Backlights work. Replaced t-con board with new one, but not fixed. What next?
Main board. T con board is only involved with video issues. Main board goes both ways and since you already replaced the T con board that is your only alternative. U got backlite so inverter board is good.
Nov 13, 2015 | Samsung Televison & Video
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Jan 19, 2015 | Polaroid 3211TLXB 32 in. LCD Television
Turn on TV, sound from program but no picture, just a bright screen. Picture begins to fade. Brand new led TV, was working perfectly fine last night.
Your TV have problem with its T-Con board. T-con board is one which drives the LCD Panel Pixels in rows and columns. As you didn't specified the brand and model number its not possible to give you the exact picture of T con board How its look like. You can find this board On the top center of the tv. Which will be covered with metal case or aluminium foil to avoid external interference. Here i have added a picture of T- Con board which used in Led Tvs.
Nov 04, 2012 | Televison & Video
. Problem with Projection Televisions Cust.
Good day!!!
That problem is usually cause of bad T-con LED controller TV board (T-con board is the responsible for processing of picture on your TV)..
This is the sample image of T-con board.
I suggest you to buy this TV part to fix your unit..
I already search the board online so you don't need to spend more time for searching parts online..
Try to click this link:
Hope it helps...
Thank you for using fixya..
Jan 13, 2012 | Vizio Televison & Video
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Samsung plasma 42 inchs with sound no picture
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
Nov 07, 2009 | Samsung PS42P2S 42 in. Plasma Television
My Toshuiba 46RV530U tv has developed an image
Sounds like you need to try reseating the lvds cables on the t-con board.This board is located at the top of the set in the center.You will have to remove the metal shield covering the board.Then you will see to flat cables connected to the board,one for each side of the screen.carefully unlock the connectors and remove and replace the cables.If this does not work you will need a new t-con board.I'm not sure about this particular model but sometimes the t-con board is only available as part of the lcd panel assembly.Good luck!
Oct 15, 2009 | Toshiba REGZA 46RV530U LCD TV
Televison & Video Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
