Question about Garden
I have spear and jackson jbc28 petrol strimmer which will not start when I press primer bulb no petrol is drawn into the bulb i have checked the spark plug and there is a spark
  • 15 Answers
SOURCE: cant start petrol enginge strimmer . starts with
adjust air screw on carbeurtor as it is probably running rich
Posted on May 31, 2010
SOURCE: I am after a manual for my Spear and Jackson Petrol Strimmer
You can download this from www.isc-gmbh.info/download/prod/21424791/3401760_01018_SPK1.pdf. The model is actually a rebadged Einhell BG-BC 30/1
Posted on Jun 17, 2010
philwalker78
  • 608 Answers
SOURCE: I need to know the
Hi, a ngk bm6a will do the trick. Regards Phil.
Posted on Apr 27, 2011
Testimonial: "Many thanks . Will give it a try . jim Hutchinson "
  • 35 Answers
SOURCE: spear and jackson petrol hedge
You need to make sure you have spark. Remove plug, connect spark plug wire, hold plug to motor to make ground. Pull recoil and take note if you have a blue spark on the electrode of the spark plug. If you do, then it is a fuel issue, most likely gummed up the carb. Try carb cleaner spray and fresh gas.
Posted on Aug 25, 2011
SOURCE: spear and jackson sht 26x looking for the petrol
20 to 1 is the correct fuel to oil ratio for spear and jackson SHT 26X
Posted on Sep 16, 2011
What is the fuel/oil ratio for a spear Jackson spjht26 hedgetrimmer
40:1 ratio is the norm, up to 50:1, you can get a 40:1 ratio mix by adding 2.5 cc of 2 stroke oil to 1 litre of petrol. Make sure you do not use car engine oil, it must be special 2 stroke oil which is what they sell for old lawn mowers and strimmers etc. If your exhuast is smoking then you put in too much oil so add more petrol...
Jul 10, 2014 | Garden
Spear & Jackson 33cc Petrol Grass Strimmer SGT33N, black fuel pipe split. How to replace it?
empty the petrol,feed the black line (the fuel intake) into the tank and grab the end of it thats attached to the filter inside the tank. now you can feed a new fuel line through into the tank and reattach to the filter. hopefully this will solve your problem ive just done this but mine still wont start, either flooded or spark plug. by the way i bought mine new and the fuel line was split.
Jun 05, 2013 | Garden
Will run only with choke on
This is fuel starvation ( it is running too lean ) if it has been stood from last year with the same fuel in , the fuel may have gone stale and bloced the jet in the carb, keep priming and starting this may eventualy clear the carb, if not the carb will have to come off and clean through, ley us know if you need help servicing the carb.
Nov 25, 2012 | Garden
Can't start the strimmer. It is a petrol strimmer, Partner Colibri. Is there a technique other than pulling the cord? Does it need more than just petrol? would be pleased if you could help. Regards...
Start procedure, switch the ignition switch on, press the primer bulb as many times as it takes to 3/4 fill the bulb, put the choke to the full position,hold the throttle trigger open, crank the engine until it fires once, move the choke to the centre position, crank the engine until it fires up and runs, once warm move the choke to the open position.
Jun 11, 2011 | Garden
Spear and jackson sht 26x looking for the petrol
Jun 04, 2011 | Garden
Nov 15, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
