Question about Briggs Garden
What are head bolt torque specs. for briggs and Stratton 4.75hp horizontal shaft mower engine
freetek
  • 5568 Answers
SOURCE: bolt torque specs
I have used Haynes service manuals for (hate to admit it) many decades and I recommend you check to see if this one:
http://www.amazon.com/Haynes-Toyota-Automotive-Repair-Manual/dp/1563923513
doesn't cover your engine.
I have found darned few 'holes' in their coverage.
Auto parts stores carry these and I suspect that even though sealed, the sales people will not give you too hard of a time if you explain you want to insure you are getting what you need.
Haynes is not the same as it was 20 years ago before they were acquired by Chilton but the price/utility ratio is still pretty good.
Mostly I'm annoyed by the move to cheaper paper (newsprint)that is fussier, picks up dirt, tears more easily than the better paper of yore.
Posted on Aug 20, 2008
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
  • 93 Answers
SOURCE: Cylinder head bolt torque setting for a
Search Briggs on the Web, You can order Manuals there. The torque is in in. pounds. Need more info ! A just get them tight and all about the same will work, stagger the bolts in the Head when tightening ( one bolt, one side then the other until done.) Then check them all.
Posted on Sep 15, 2009
  • 5 Answers
SOURCE: Head bolt torque specs?
I really really really hope you turned the bolts an additional 90 degrees after torquing to 22 Ft-lbs. Otherwise, you may be taking that head off again.
Best of luck,
David
Posted on Mar 15, 2010
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
FAQ Small Engine Specifications Briggs Stratton Specs
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
How to remove piston from 17hp Briggs & Stratton mower engine?
You take the head off, remove the crank case cover, take the bolt off the piston journal on the crank shaft, push the piston out of the top of the engine. To get it back in you are going to need a ring compressor and should use plasti-guage to check clearance on the crank
Oct 13, 2015 | Briggs & Stratton Measuring Tools &...
How do I remove the horizontal shaft
the motor you are working on has a split block and you have to take the motor off and remove the bolts holding the two halves of the block apart. this motor doesn't have a separate removable head. it is cast as two pieces and in my opinion makes more work for some repairs. hope this helps
Oct 13, 2015 | Briggs AND Stratton Intek Briggs &...
What is the head gasket torque spec for a 8.5 horse power horizontal shaft brigg and Stratton engine.
not nearly as critical as you think. I bet 40 ft lbs on all bolts would be fine. It's more the consistency among the Bolts than the actual torque
Sep 28, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Engine torque specifications
this will get you started for your specs. It is a PDF so you can print it.http://www.perr.com/pdf/ms3992_041008.pdf
Sep 07, 2014 | Briggs & Stratton Garden
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
27 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
