Question about Panasonic Televison & Video
Panasonic TC-50x1 N tv wont turn on.when i unplug, then plug back in,it will turn on then shut off again?
The red power indicator light blinks 6 times continuously?
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
SOURCE: panasonic viera hd tv th 50pz80u
We had a Pioneer that did the same thing. We called a Pioneer Service Center. It appears there was a recall on the Power Supply. They fixed it in our home at not charge.
Posted on Jan 07, 2009
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 13 Answers
SOURCE: TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
Posted on May 28, 2009
rulds2008
  • 3866 Answers
SOURCE: blinking red light, no picture or sound
You goingto need to replce the powersupply inside www.partstore.com should have it or preorder it for you from the manufacture i think there around $150 they could be cheaper. Another option is Ebay. thanks for using fixa.com please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 21, 2009
Panasonic p65vt60 6 blink code
Power board...I bet you have swollen capacitors...
Sep 24, 2016 | Panasonic TC-P65VT60 65" Plasma TV...
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Why is my panasonic tc-p46x3 is blinking 14 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Aug 10, 2014 | Panasonic Viera Plasma TV TC-P46X3
Panasonic viera wont turn on after power surge
My panasonic 42 inch does this if the power goes out or tv is unplugged prior to powering the tv off first. I unplug the power from the wall wait 2-4 days max then when I plug it back in the tv comes right back on with no problems. Don't know why I have to wait so long to plug it back in
Oct 30, 2012 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic viera TC-P50G15 tv cut off in the middlde of watching it, red light kept blinking on tv, dont recall how many times, unplugged tv then plugged back in at that point no lights came on & tv...
Tries tv unplug,replug it back like about an hour later,for the tv to a resetting itself back to the factory setting.The tv might work again,if not the tv power supply board is the problems and the causes.The tv power supply board it is shorted and dead some how.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 22, 2011 | Panasonic TC-P50G15 50 in. Plasma HDTV
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jan 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
