Question about Technics Audio Players & Recorders
Technics SL-MC70 Compact Disc Changer "Error" message; I moved this with discs inside it. Now it just shows "Error" when I try to play a disc in it. Can it be helped? Thanks, Lynn
    New Friend:
    Problem Solver:
  • 15 Answers
Yes, it definitely needs help with the CD player, maybe a professional that knows how to fix electronics might help you.
Posted on May 13, 2017
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
Error message appears cd won't play
I don't have much to go on here. Can you post the actual message that shows up? Usually on these units, either the mechanism gets out of time or it gets jammed. The actuall message will help to determine which.
Thanks,
Dan
Mar 11, 2011 | Technics SL-MC70 60-Disc CD Changer
Technics 60 cd changer cannot see disk in changer
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the CD Changer not reading discs is a bad drive. The following website sells the drives and does installs:
http://store.richspsxparts.com/wiiredvddr.html
This drive should fix any reading issues you are having with your disc, or issues inserting your disc or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your CD Changer.
Hope this will help...
May 26, 2010 | Technics SL-MC70 60-Disc CD Changer
Random play
Hi - You can download the manual by clicking the link underlined in blue below:
SL-MC70
See page 17:
Note this feature requires the remote control!
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Technics SL-MC70 60-Disc CD Changer
Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Oct 06, 2006 | Technics SL-MC6 CD Player
50 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
