Question about GPS
How do I set a waypoint on the Garmin 158 GPS? ( the owner's manual shows everything except how to set a waypoint)
djnick989
  • 1067 Answers
SOURCE: I have lost my Mapsource Setup cd for my Garmin GPS
  1. Download MapSource software updater from Garmin. The version as of December 4, 2007 is 6.13.6, and the trick also works on Map Source version 6.13.5.
  2. Unpack or extract the content of MapSource_6136.exe
    downloaded using WinRAR.
  3. From the extracted files, run MAIN.msi.
  4. Then, run Setup.exe. Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error.
  5. Garmin MapSource now installed.
Posted on Feb 02, 2008
SOURCE: Cannot delete waypoints from a
Press find > waypoints > menu > delete...This will let you delete all waypoints or waypoints of any given icon of your choosing.
Posted on Dec 04, 2008
RPFinney
  • 385 Answers
SOURCE: HOW TO ENTER WAYPOINTON GARMIN GPS 72
If you check the link below, got to the top of page 27,
How to enter waypoints on a Garmin GPS 72.
Here
Hope this helps
Regards
Posted on Apr 16, 2009
marked
  • 6487 Answers
SOURCE: where do I get a owners manuel for my Garmin GPS
You can download the user manual for this unit from this link
http://www.retrevo.com/support/Garmin-255W-GPS-manual/id/13724ci769/t/2/
Posted on May 04, 2009
  • 68 Answers
SOURCE: unable to find free down load for owners manual
go to this link and download the manual from garmin free of charge there are also links to update firmware etc also.
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
if this answers your query please rate me accordingly.
regards
Posted on Sep 14, 2009
I have a Garmin etrex handheld unit. The gps data from it does not correlate with google maps gps coordinates at all. There is a 30 mile, not feet but mile difference in the waypoints. Any idea what I may...
You need to make sure your GPS unit and Google maps are using the same map datum.
In your user manual:
http://static.garmincdn.com/pumac/eTrexLegend_OwnersManual.pdf
Page 44, Setup Options, Units, Position Format: I suggest setting to:
hddd.ddddd as this is the digital format and easier to read
In Google Maps, right click - Drop Latitude/Longitude marker and this should show the co-ordinates in digital degrees. Alternatively, you can hit the SEND button in GoogleMaps, and it will send the marked location to the GPS via the Garmin website. You may have to install the Garmin plug-in into your browser first, but it's well worth it.
If this solves your problem, please come back and rate our solution, thank you.
Dec 19, 2010 | Garmin eTrex Legend GPS Receiver
Garmin gps 12 loss of data
I had the same thing happen. The problem is that the internal lithium battery is shot. Solution: phone Garmin at 1-800-800-1020 x 2,2,1. You send the receiver in along with a $42.41 check. They will probably replace the unit. They will explain exact procedures when you call.
Hope this helps.
Joan
Jan 04, 2010 | Garmin GPS 12 GPS Receiver
Here
Hope this helps
Regards
Dec 24, 2008 | Garmin GPS 72 GPS Receiver
How top use a garmin etrex g p s
Your manual will tell you how to use waypoints, mapping to a waypoint, and how to do backtracking. If you don't have the manual, you can download it from the Garmin website www.garmin.com. Under Products > On The Trail, find your model of GPS. On the far right of the page, you will see a link for the manual.
Oct 15, 2008 | Garmin eTrex Legend GPS Receiver
Cannot delete waypoints from a garmin GPS 60
Aug 11, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin gps 60 .How do i clear all waypoints?
In your manual, on Page 23. Press ENTER on the waypoint to view the waypoint information page, scroll to DELETE, press ENTER and the waypoint is deleted.
Aug 08, 2008 | Garmin eTrex Vista GPS Receiver
Grid bearing
If you press in the control stick, it will make a waypoint at your location and you can see the co-ordinates. The numbers can be displayed in various ways, all depends the settings you have used in the Etrex.
Your bearing will be on your Navigation Page.
http://www8.garmin.com/manuals/eTrex_OwnersManual.pdf
Feb 22, 2008 | Garmin eTrex GPS Receiver
Plotting Waypoints
Here's the link to the user manual if you need it; http://www8.garmin.com/manuals/GPS60_OwnersManual.pdf Garmin says; To manually enter in the coordinates for a waypoint on the 60 or 76 -series units, use the following steps: Press and hold the 'Mark' button. Use the up arrow to scroll up to the "Location" field and press 'Enter'. A new box pops up to enter in the new coordinates. Go to "OK" and press 'Enter'. Select "OK" at the bottom right corner to save all changes. Hope this helps :)
Jul 17, 2007 | Garmin 60 GPS Receiver
Not aquiring satellite or local time
I had a similar problem, and Garmin recommended that I reset the user data by holding "Power" and "Esc" when you turn on the unit. I think it remedied my problem to some extent. However, note that this will indeed delete all of your waypoints and other data, so be sure to back them up somehow (even if it means manually writing down the waypoint coordinates and re-entering them later) if you don't want to lose them. Good luck.
May 02, 2007 | Garmin Emap GPS Receiver
GPS Logo
29 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
