Question about Cell Phones
How do I install micro SD card properly - Cell Phones
  • 5 Answers
SOURCE: Micro-sd card capacity
absolutely. the first time you pop it in, your phone will ask you if you want to format it. select 'yes' and then you will find several new folders for pix, flix, music, etc.
Posted on Nov 21, 2007
SOURCE: Freezing when I install a micro sd card into my samsung eternity
i had the same problem. so i try whatever i can
- i remove battery, put it back on, turn the phone back on. seems like it works for 3-5 minutes and freeze again
- i remove sim (only ),memory card still in there, and turn the phone back on..let it sit with no sim. and 3 minutes later it freeze again
- i remove sim, remove micro sdhc, reset the phone , the phone automatic woks... it never freeze ( no sim+ no memory card )
- i put the sim back on, no memory card, turn the phone back on and it works!!!!!!! i try these 2-3 times without memory card. works normal!!!
so..i think its a memory card issue. may be the phone doesn't like it. i have 2gb. kingston. or i have to buy a new card again.
for now its still working without freeze up for shut down by itself.
hope it help :)
Posted on Jul 22, 2009
nokia 5300 card rider problem
Posted on Sep 21, 2009
  • 821 Answers
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Posted on Apr 16, 2010
SOURCE: My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Posted on Oct 21, 2010
My MicroSD card is not storing data on my tab A 10.1.
Your Micro SD card is the external memory. Move stuff from the internal memory.
Apr 12, 2017 | Cell Phones
How do I activate my micro sd card in my Samsung galaxy grand prime cell phone
Insert your new micro SD card first on the phone then go to settings> storage> format SD card to make sure that the card will work properly.
Nov 04, 2016 | Samsung Cell Phones
When I enter my memord card in nokia 311 it say the operation is failed and the memory card is not to remove virus from my memory card and replace my music and Image.
All you have to do is
Step One (save data)
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
When do the data recovery process, you can find the cause of damage to the micro SD.
Cause of the damage the virus infected (solutions: see method 1)
When saving data, be careful, do not recover the virus file. You must choose the proper file for the recovery.
Cause of the damage bad sectors (solutions: see method 2)
Damage to the partition table (solutions: see method 1)
Micro SD write protect. Characteristics: (solutions: see method 3)
1. Micro SD can be opened, the data can not copy and paste (from the micro SD into a computer, or from computer to the micro SD). When the format, the message "Removable media write protect".
2. Micro SD can not be opened, and when the format of the message "Removable media write protect".
Step two (repair micro SD)
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Method 2
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
Method 3
To write protect a micro SD cases, 40% probability of success.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
I hope this information helps. Thank you for using FixYa!
Oct 02, 2011 | SanDisk 2GB microSD Memory Card
My nokia 3110c is not switching on properly it auto matically switching off within 2-3 second yesterday i had download some wallpapers from internet it might be due to virus so what i should do
try to reformat your micro sd memory card,you might have downloaded a corrupted doing so will erase all of your files installed in your micro sd memory card.
Aug 22, 2010 | Nokia 3110 Cellular Phone
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
Cannot install 4GB card into TL220. Do I have the
According to Samsung's page on this camera, the following memory can be used:
External Memory(Optional) : Micro SD (up to 4GB)
Micro SDHC (up to 8GB)
4 GB is acceptable, but I think you do not have the correct type of card. You should be using a Micro SD or "Micro Secure Digital" (up to 4GB capacity) or a Micro SDHC or "Micro Secure Digital High Capacity" (up to 8 GB capacity) card. This is very different from an SD or SDHC card. These Micro cards are very small (smaller than your thumbnail) and are often packaged with an SD adapter card. Regardless if sold with or with out the adapter, the package should say Micro SD or Micro SDHC on it somewhere.
Oct 02, 2009 | Samsung Cameras
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
I cannot install my micro sdhc card into my Samsung Eternity phon
the micro sd card goes just under the sim card, sideways. you have to turn it upside down and push kinda hard. if you look really close, it says micro sd on the phone right where the slot is.
Apr 11, 2009 | Samsung Eternity Cell Phone
Problem with micro sd card
Does the micro SD card have a lock/unlock slider for write protection?
Is it a high capacity microSD not supported by imate jam, and have you already formatted the microSD?
Mar 14, 2008 | i-mate JAM Pocket PC
SD Card causing problems?
The V3m has an inherent flaw with the Sd Micro Memory Card. Installing the card, which fits extremely tight can damage the electrical contacts in the micro chip socket. This can result in low battery life due to a short to metal chassis of phone and not being able to communicate properly with memory chip. I had my first Razr V3m replaced by Sprint after only 2 days of ownership.When I got my new phone I carefully filed the tab on the Sd Micro Chip so insertion and extraction is much easier.
Nov 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
