Question about Panasonic Lands Phones
We have a Panasonic Phone system with 6 lines. We constantly have an error when someone is on a call, it just cuts off (you are on the call and you hear some bleeps and then just cuts off.
When you try to press a line to ring back it comes up "Line not assigned", you need to wait approx 30 seconds to get a line. If 2 or 3 people on calls at same time, then all phones cut off in this manner. It doesn't happen to all calls, just random.
  • 106 Answers
SOURCE: line cut off problem
That is a common problem with this model, normally happens after a storm passes through. Unfortunately there is no easy fix for on site, it would need to be sent in for repair or replaced. You can google Siemens Cordless Repair to find service facilities.
Posted on Jan 14, 2008
  • 65 Answers
SOURCE: phone does not ring
have you called the support line for assistance?dial 1.800.511.3180
Posted on Jan 29, 2008
  • 2460 Answers
SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Posted on Sep 04, 2008
  • 32 Answers
SOURCE: My Nortel Meridian M2008 phone will not ring
it may be turned down to the program key and use the scroll bar below the keypad to find your option...hopes this helps
Posted on Dec 20, 2008
SOURCE: nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Posted on Jun 27, 2009
1 line stops working on 2 line phone
No Earth "ground" on that second line.
Apr 05, 2016 | Lands Phones
Dect phone manual
Standby mode is when the phone is not on a call, you're not dialing one, and you're not doing anything with the menus. It's standing by, waiting for you to call or for someone to call you.
Aug 09, 2014 | Panasonic KX-TG4022N DECT 6.0 Single-line...
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 18, 2014 | Panasonic BTS Panasonic KX-T7433 Black...
Don't see my phone line once someon else picks up a lilne on My Panasonic KX T7433
Start by pressing PROGRAM 99 on the phone and press the line buttons one a t a time. It will tell you what CO(central office) line is assigned to the button.
They should be in sequence 1,2,3,4 etc. If they don't, dial 0 + 0x STORE to program it and make it work.
Aug 22, 2012 | Panasonic KX-T7433B Corded Phone
Panasonic KX-TG6071S
Check its battery. There is a rechargable battery. If the battery may look like good, it may ahve sufficiant curretnt carrying capacity. If so, this type of fault occur. Repalce the battery. OK.
Feb 11, 2012 | Panasonic DECT 6.0 Expandable Cordless...
I have a Panasonic 7731 here at my desk. It rings audibly when any of our 5 or 6 lines is called. I'd like to narrow it down to only ringing when someone calls my line (my phone #).
Check out the system programming manual for your particular cabinet. Somewhere, like in the 40x's, there's an instruction to program ringing for each extension in day, night, and lunch modes.
Jun 01, 2011 | Panasonic KX-T7731 Corded Phone
I have a kx-t7731 panasonic phone system. How can I tell how many phone lines I can have?
You have a 7731 PHONE. The system it's connected to has a model number as in TA 624 TA 824 TAW 848 etc. The first digit (or digits) tell you how many phone lines you can have, but you may not have all of the hardware to make it happen. An 824 has 8 lines, but they come in 3x8, 3x8 and 2x8 cards that fit into the cabinet. A 624 has the capacity for 2 3x8 cards but can have 3,5 or 6 lines, depending on the cards installed.
May 02, 2011 | Panasonic KX-TA824PK Phone
We have the Panasonic KX-T7433 model of phones at our office. Yesterday I set about to re-programme some of the extensions and now, as a result I have lost the outside line for the phones that I have been...
I just found this, which had the process for programming a CO button as a one-touch. And it worked. It's a bit easier to follow than the panasonic manual so hopefully it will have an answer.
Jul 23, 2008 | Panasonic KX-T7433B Corded Phone
Extension Light will not switch off even though line not being used
perhaps there is a stuck key, or a function enabled, such as DND, you could check by unplugging the phone, press and release every key to see if one sticks, then plug phone back in and wait for it to perform self test with switch unit, here is link to user manual
Jan 09, 2008 | Panasonic KX-T7730 Corded Phone
Programe my phone KX-T7730
The phone you have (KX-T7730) requires a phone system to operate. This phone can be installed on a few different Panasonic phone systems. You need a "programming" manual for the phone system to do what you want (not a user guide) so you will first need to determine which system you have. Look for a part number on the system itself, it should start with "KXT" just like the phone.
Sep 16, 2007 | Panasonic KX-T7731 Corded Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
