Question about Sport & Outdoor - Others
Even plus stool by Calligaris. Stool is at highest level and will NOT release. HELP?
I called in a professional .. He worked out the release of one of the stools and actually the second one also.. The one is now at the highest and stuck. This should not happen to a relatively new Calligaris product considering, also the price.Thanks Ron Madore.. Miami, Fl
  • 302 Answers
SOURCE: How to recover the cosco step stool
most home stores have this material in the carpet section. Use Plio-Bond glue and you'll be all set.
Posted on Sep 29, 2009
chitownbob45
  • 316 Answers
SOURCE: the toilet has water running continuously from the
bad shut off float pull the float up manually does that shut it off if so adjust float to go off at a lower water level. If it doesnt replace it. The float is attached to a water shut off valve as it rises to a certain point which you set, when it reaches that water level it shuts off the water.
Posted on Oct 18, 2009
mikadot
  • 2113 Answers
SOURCE: what makes the water in the stool just swirlls
A toilet that has water turn but little of it goes down has to do with the speed that the water is released from the tank   you need the flapper to stay open longer and wider    you can purchase some with floats or mechanisms to catch air and stay above the water in the tank long enough to have good water flow    Make sure that the water in the tank is adjusted up to the water line marked inside the tank   If it still has trouble going down then maybe there is a vapor lock or blockage in the opening of the flange   a vapor lock is when an inadequate vent  or no vent is installed to allow a column of air to go down as the water goes down   poor wax seal installation and or tampons, clumping kitty litter etc can block the flange   to find it  remove the toilet and look down  also check up from the underside of the toilet when it is removed
Posted on Nov 08, 2009
  • 4350 Answers
SOURCE: fluidmaster stool flushing system: the float cup
REplace the assembly
Posted on Sep 22, 2010
#1 Taper
  • 1041 Answers
SOURCE: How do you thread the
Here is my Tip on this problem: http://www.fixya.com/support/r6270682-trimmer_weed_eater_string_replacement
Good Luck!
Jim
Posted on Aug 13, 2011
How to assemble mainstays swivel bar stool
Assembly Video - Boraam 29-Inch Augusta Swivel Bar Stool ...
? 1:30
www.youtube.com/watch?v=Qou7Y5FW8QA
Nov 20, 2012 - Uploaded by hayneedle.com
Learn more about assembling the Boraam 29-Inch Augusta Swivel Bar Stool from a knowledgeable ...
Aug 25, 2015 | Mainstays Metal Swivel Bar Stool 29, Black
I need instructions for sonoma 29" swivel bar stool
this bar stool can be adjustable the height. You can operate it by the handle under the seat.
Jan 20, 2014 | SONOMA life + style Adjustable Swivel Bar...
Where can i purchase the rubber treads for the steps on a cosco step stool
http://www.coscoproducts.com/eng/Products/Step-stools/
http://www.coscoproducts.com/eng/Contact-Us
I'm guessing this is an older stool you have that you need to repair. the model number you provided doesn't ring any bells at Cosco.
Give them a call or send them an email and see if they can help. You're other choice is to look at a hardware store for something to use to replace the worn treads. Good luck.
Sep 12, 2012 | Cosco Juvenile Samsonite Cosco 11-839GGO:...
What a camp stool?
The camp stool is a lightweight camping chair, in most cases not over one pound; they are compact and can fit just about anywhere. Its downside is that it has no backrest but there are some camp stools with backrest only they weigh around 3-5 pounds.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
What type of bar stool is best for overweight individuals?
The best type of bar stool for someone who is overweight to sit in is a floor mounted stool. This type of stool is securely attached with bolts to the floor beneath it, ensuring better support and stability. If you don't want to bolt down your stools, your next best option is to get a four-legged stool. Four-leg bar stools disperse the weight of the person sitting on them evenly. On the downside, four-leg stools have a higher risk of tipping over.
Jul 24, 2012 | Furniture
My Kohler Cimarron has a blockage. I have used a plunger and tried dish soap and hot water. also poured 4 buckets of water. Not blocked by a foreign object. plz help JMP
Probably something stuck in the Trap of the stool unless your main line is stopped up. If you cannot plunge it, you may have to take the stool loose from the floor, unhook the water line, and turn it upside down out in your yard. You will be able to view right up into the trap of the stool . Otherwise, you can go buy a small stool snake and try to root it out on your own. Good luck, this is no fun.
Apr 21, 2011 | Kohler K-11465-0 White Cimarron Comfort...
Toilet flushes weakly and two times
After working for ROTO-ROOTER for 20 + years, I have come across this problem more than twice. There are many problems that can be included, but let's start with the most simple and go from there. Step 1... Check your roof vent to see if it is obstructed with debris, such as birds nest, frozen ice, dead animal...etc..... To check this you must go onto the roof and find the sewer vent(it is not hard to find as it smells like sewer). Visually look into the vent even using a flashlight to make sure there is nothing obstructing the vent pipe. certain things can clog your vent such as Debris,Birbs Nest, Ice, dead animal,Etc..A drain line needs a air vent so water can flow....If nothing is visually seen , have someone flush the stool. If you cannot see any obstructions and HEAR THE FLUSH, Your Vent is okay. Check out plumbing and venting on the internet for more reference. If this is not your problem then you must pull the stool and see if there is an object stuck in the toilet......Comb, toothbrush, Etc... The best way is to pull the stool from the floor and look from the bottom of the toilet to see if there is an object stuck inside the stool.Turn off the water supply and disconnect it from the tank. Go to your local hardware store and buy 2 wax rings with plastic flanges and a set of flange bolts(these are cheap and can be returned if not used).Turn off the water supply to the toilet tank and flush it to drain all the water from the tank and the stool. You can use a shop vac or an old towel to remove the water. After removing the stool, lay it on its side and look from the bottom to see if there are any obstructions. You may need a mirror and flashlight to see inside the gooseneck of the stool. If you cannot see any obstructions, you can try to dump a 5 gallon bucket of water through the bottom of the stool to push the object out the way it entered. NOTE: When reinstalli8ng the stool, be careful not to over-tighten the floor flange bolts as you might crack the toilet......Joe
Jan 01, 2009 | American Standard Colony 2388.012.222...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
