Question about The Computers & Internet
The 3-Point pin plug supplied with my phone will not fit my sockets at home... do I need a conector'
    Top Expert:
  • The Master
  • 77,544 Answers
You need a wall plug adapter. Check eBay.
Posted on May 18, 2017
Maanita
  • 1142 Answers
SOURCE: My Zoom H2 microphone has
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 28, 2008
  • 65 Answers
SOURCE: Fitting a towbar for a caravan with 13pin europlug
black socket, black 7 core wire
pin 1 yellow left indicator
pin 2 blue, rear fog light
pin 3 white earth
pin 4 green right indicator
pin 5 brown right side/tail light
pin 6 red brake lights
pin 7 black left side/tail light
Grey socket grey 7 core wiring
pin 1 yellow, reverse
pin 2 blue, supplementary feed (ignition)
pin 3 white, earth
pin 4 green live feed (battery +)
pin 5 brown not connected
pin 6 red supplementary feed (ignition)
Pin 7 black earth
On the discovery there is a purpose made plug behind the panel on the drivers side rear, behind the rear lamp
i think the relay you have bought is for lamp failure you just need a normal 4 pin 30 amp relay.
Good luck Davelee
Posted on Mar 24, 2009
  • 1138 Answers
SOURCE: i need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Posted on May 26, 2009
  • 1138 Answers
SOURCE: digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
  • 3 Answers
SOURCE: Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Posted on Mar 03, 2010
JVC MV-P612U Professional Microphone Wiring to XLR
The MV-P162U is a stereo mic designed to plug into a JVC professional camcorder. dates from the 1990's and was very expensive.If the 6 pin plug has not been cut off, and you can get a socket to fit, then going clockwise around pins (or wiring side of socket) from the locator.
1) R phase +
2) +8V supply
3) -ve supply/gnd
4) L phase +
5) L phase -
6) R phase -
suggest a small breakout box. tested it with a 9v battery - the drain is 14ma. could run from 12v via a 285 ohm (approx) resistor with a 47uf cap across the mic supply.
Apr 15, 2011 | JVC MV-P612U Professional Microphone
What does it mean when a gas cooker needs hardwiring
It means that it does not have a cord and a plug to just plug it into a wall socket...
It needs to be "hardwired" into the electrical circuit with a regular piece of wire...
heatman101
Dec 13, 2010 | New World G60m Gas Single Oven
Wat goes where from the power supply
on the newer psu's (power supply units) they are labeled. if they are not there is a basic rule. if it fits the socket without forcing it, use it there. there are many 4 pin plugs on a psu. these are all identical and all are exactly the same. they can be used anywhere a 4 pin connector is needed. newer psu's also have 6 pin, 8 pin and sata plugs. 6 pin and 8 pin are generally for video cards that are pcix sata pugs are for any sata drive, like a dvd or a hard disk. also there is a 24 pin or a 20 + 4 pin connector. this goes to the mother board.
Jun 26, 2010 | Packard Bell (190169) Power Supply
How to connect power supply to intel desktop board of d845wn
hmm strange question but you cant really get it wrong you plug the 20 pin conector from the power supply into the board then plug the little 4pin block which is on a diffrent cable into the little 4 pin block on the motherboard there all shaped to fit the conections so you cant get them wrong
Sep 24, 2009 | Intel Desktop Board D845WN Motherboard
What plugs do i need for the printer, i recently moved and have no attachments now
I've got a 1180 & it looks as if you need a standard mains mains supply cable with a 2 pin socket - similar to those which fit stereo units and a computer to printer cable - one end usb and the other a device end socket to fit the printer at the back. Not all generic device cables will fit, you need one which fits the printer
Sep 23, 2009 | Lexmark X1150 All-In-One InkJet Printer
Verifying power connection 20/24 pin?
yes only 20pin but if you have a 20+4 pin its a ok to use just u need to cut or remove the 4pin..
May 23, 2009 | Acer Computers & Internet
pin 3 white earth
pin 3 white, earth
Pin 7 black earth
Good luck Davelee
Mar 19, 2009 | 1997 Land Rover Discovery
CPU fan that cam togther with my CPU has 3 pin conector, but the motherboard has 4 pin Conector. That dosent sems to work ut
The extra pin on the motherboard is for a speed sensor connection which your fan does not have. The plug on the fan cable has two plastic tabs which fit over a tab on the motherboard connector. Just line the tabs up and the plug will fit properly. The fourth pin on the motherboard just won't be used with your fan.
Dec 14, 2008 | Computers & Internet
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
51 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
