Question about Car Audio & Video
Need3ingearformoter Needpartsformeatgrindesa3ingearformotermodel#3000w-n
Eliminator 3000W no 120 V power. Blinks 13.6v/0 Is there any out fuse? Overheat breaker?
this is NOT a dryer,it is an inverter,yes there is a fuse,there also is a reset on the gcfi outlet,you may have burned it out,by running a motor with it,start up on a motor can be more than 3000w,depending on the motor or inverter,the inverter was not made to run motors,read your owners manual for more info. there also could be a problem with your battery connection,check that and make sure that the inverter is getting 13.6 volts,that is why the light flashes,it isnt getting enough power
Mar 16, 2015 | Dryers
Inverter keeps showing overload red led when its not overloaded
if there is no short circuit any were then the overload control may be bad
Dec 18, 2009 | Vector 3000w
Not charging after replacing batteries
dear sir
i changed my battery last year on mars 2008 last week i have problem my battery is very low
brahim ghachi
best regards
Oct 09, 2009 | HP Compaq R3000XR Shuko (192186-B33)...
Inveter trouble
There is a fuse inside the cover
Dec 29, 2008 | Xantrex Technology Heart Freedom 30...
How do i wire a qvc subwoofer to a 3000w 1ohm stable monoblock amp
depends on the amplifier if you have a mono block amp or a regular 2 output amp if it is 2 output make sure to bridge and that means the negative to one output and positive to the other output then need to find out the rms on the speaker. the amp should have the ability to adjust it you might want to get a digital multimeter set it to watts and make sure you only set it to the RMS of the speaker because max handling should be the 1800 and usually the RMS is half the max so it should be 900 w again it depends on the amp and were the adjusting knob is and or if it has one
Nov 04, 2008 | Car Audio & Video
Service manual / wiring diagram
I need a Manual and parts list for a Bravetti K5345H Microwave-Convection Oven Please help!!!
Mar 03, 2008 | Microwave Ovens
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
