Question about Kitchen Appliances - Others
If you put 1\4 cup of liquid in 1 gallon, how much would you put in 2 cups?
  • 2,189 Answers
0.3125 fluid ounces per pint UK 0.25 fluid ounces per pint USA
Posted on May 12, 2017
    Sergeant:
  • 330 Answers
2 cups = 1/8 gallon
1/4 cup = 2 oz.
You need 1/4 oz. liquid per 2 cups of water
= 1 1/2 teaspoons
If you have 2.5 pints and you add .5 cups how much do you have
Depends where in the world you are and how big your cup is.
Recipes were designed to use cups as a measure because as long as the same cup was used the proportions remained the same regardless of the cup size and each recipe could be followed exactly.
Interfering busybodies ruined a perfectly good system by deciding a cup should be approximately half a pint or 8 fluid ounces, a good deal larger than the average teacup and as you will see in the chart of new-fangled measures below, they decided a teacup is actually half a cup...
I think you should now be equipped to answer your own question...
Dry & Fluid Measures Unit Abbrev. Defined fl oz mL
[note 1] Binary Submultiples drop dr., gt., gtt. (plural) 1?96 tsp 1?576 smidgen smdg., smi. 3?128 tsp 1?256 0.115522 2 smidgens = 1 pinch pinch pn. 3?64 tsp 1?128 0.231043 2 pinches = 1 dash dash ds. 3?32 tsp 1?64 0.462086 2 dashes = 1 saltspoon saltspoon or scruple ssp. 3?16 tsp 1?32 0.924173 2 saltspoons = 1 coffeespoon coffeespoon 3?8 tsp 1?16 1.84835 2 coffeespoons = 1 fluid dram Fluid dram [note 2] 3?4 tsp 1?8 3.69669 2 fluid drams = 1 dessertspoon (Australia) teaspoon (culinary)[note 3] tsp. or t. 1?3 tbsp 1?6 4.92892 2 teaspoons = 1 dessertspoon dessertspoon [20] dsp., dssp. or dstspn. 2 tsp 1?3 tablespoon tbsp. or T. 1?16 cup 1?2 14.7868 2 tablespoons = 1 fluid ounce fluid ounce fl.oz. or oz. 1?8 cup 1 29.5735 2 fluid ounce = 1 wineglass wineglass wgf. 1?4 cup 2 59.1471 2 wineglasses = 1 teacup gill or teacup tcf. 1?2 cup 4 118.294 2 teacups = 1 cup cup C 1?2 pint 8 236.588 2 cups = 1 pint pint pt. 1?2 qt 16 473.176 2 pints = 1 quart quart qt. 1?4 gal 32 946.353 2 quarts = 1 pottle pottle pot. 2 qt 64 1892.71 2 pottles = 1 gallon gallon gal. 231 in3 128 3,785.41 2 gallons = 1 peck
Jan 04, 2018 | Cars & Trucks
I need to find out how much liquid to put I a 25 gallon
2 cups. you answered your own question.
Aug 09, 2017 | Garden
If 1/4 cup of a product is used for one gallon, how much of the product would you use for 2 cups?
That is a bit obvious. Find out how many cups are in a gallon then divide by the difference
Jul 02, 2017 | Coffee Makers & Espresso Machines
How much is13 cups to gallons?
1 Cup = 8 oz.
1 Gallon = 128 oz. (16 cups)
13 x 8 = 104 oz
104 divided by 128
or
13 divided by 16
Jul 16, 2016 | Wine & Spirits
How many cups are in a quart?
1 Quart [Fluid, US] = 4 Cups [US]
1 Quart [Dry, US] = 4.65458877 Cups [US]
1 Quart [UK] = 4.54609 Cups [Metric]
I've copied and pasted this info for you hope this helps.
Feb 23, 2015 | Motorcycles
Missing measuring cup for Bialetti tuttopasta machine
Here are the measurements for basically every pasta maker:
Full Load
Liquid: 2 eggs and water to total 7 oz.
Flour: 3 1/2 cups flour with a small amount of olive oil (1 tsp?)
Half Load
Liquid: 1 egg and water to total 4 oz.
Flour: 1 3/4 cups flour with a small amount of olive oil (1/2 tsp?)
Dec 01, 2013 | Ronco Automatic Popeil Pasta Maker
How much liquid in the liquid measure?
2 EGGS PLUS WATER = 3/4 cup plus 2 tablespoons (not all recipes in the manual
use eggs, but all do use 2 teaspoons of oil which would be included as part of
the liquid. For recipes using an egg or eggs, put the oil and egg(s) in the
measuring cup then add water to total 3/4 cup)
ALL WATER = 2/3
cup
ALL EGGS = 1 cup
Dec 23, 2012 | NIB Betty Crocker Automatic Pasta Maker...
Prima pasta maker ppm001 have lost cup
ALL WATER = 2/3
cup
ALL EGGS = 1 cup
Nov 28, 2012 | Kitchen Appliances - Others
Can set at 1/2, 1, or 1 1/2 gallon and get only 2
There is a set lock on the timer board, if you've tried that already then check solenoid valve, make sure it works, if yes then problem is timer board.
Mar 25, 2009 | Bunn SINGLE, includes One 1 Gallon Server
Regal ware k6751
Look at the box first. Many times it will have instructions on it. However sometimes it may not and have only the the dry ingredients. If the box has no instructions, see how many cups of flour the mix uses. If it uses 3 cups of flour total, the mix is for a 1 1/2 pound loaf. If the mix uses 2 cups of flour it will make a 1 pound loaf. Box missing this info? It's time to take the flour out of the box to measure it with at measuring cup. Mixes sometimes combine all the ingredients together so it will measure bit more than 3 cups for a 1 1/2 pound loaf or 2 cups for 1 pound loaf. After finding out how big the loaf is going to be then get the bread pan and instruction manual and start constructing the dough. I'd find the recipe in the manual that matches the mix the best to find out how much liquid to use. (for a classic whit its 1 cup for 1 1/2 pound leaf and 3/4 cup for 1 pound loaf) Then I put the liquid in the pan first along with butter (if necessary), followed by the dry ingredients in the mix with the yeast at the top. Put the pan into the bread machine and select 1 or 1 1/2 loaf or if it is a french or sweet bread. Press start. Unfortunately I have a different machine than you do, but I think this will help.
Jan 15, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
