Question about Keurig Coffee Makers & Espresso Machines
What do I do when my keurig is set on 8 ounce and it keeps brewing
When I make a cup of coffee I have it set for 8 ounces. Twice it has jut kept on brewing. I unpulged it left like that for a day it work right for a couple of days now it is back to not stoping.
    New Friend:
    Problem Solver:
  • 5 Answers
This is going to sound a little funny. Try descaling it. Mine runs excessive water when it needs to be descaled and we live in an area with rather mineral heavy water
Posted on May 12, 2017
My Keurig (one year old) does not brew a full cup (I have it set for the largest cup setting) and it only brews approx 4 oz. then stops.?
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Oct 03, 2010 | Keurig B100 Coffee Maker
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
Why does my keurig require me to set the process in motion 3 times just to get 1 regular cup of coffee.
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Sep 12, 2010 | Keurig Platinum B70 Coffee Maker
Keurig coffee
Apr 28, 2010 | Keurig Elite B40 Coffee Maker
I have a Cuisinart SS-1C (I'm in Canada) coffee-maker. It works pretty well, however, I have noticed (and measured) that I get at least 2 fewer ounces than the number I select. For instance, I get only 2...
There is probably a disclaimer in the user guide, as there are in many coffeemaker owner's manuals, to the effect that the coffee dispensed to the cup or the carafe will always be slightly less in quantity than the amount of water added or desired due to absorption by the grounds. This is not a malfunction, however. The only real solution is to brew the next size up.
Jan 22, 2010 | Cuisinart Cup-O-Matic SS-1 Coffee Maker
Keurig b30 won't brew
Jan 08, 2010 | Keurig B100 Coffee Maker
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
My keurig wont brew
Sep 03, 2009 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
69 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
