I purchased one of those iPod players that has a standard (yellow) video, and both audio (red & white) connectors. The system is suppose to show the iPod screen on the remote monitor, in this case my Sharp TV, and then you can control via the IR remote that came with the iPod player. I am connecting the iPod player first to my Dennon receiver and then outputting the video to the TV via the receiver video outputs. I have tried both S-video and standard (yellow) but when I select the video input on the TV I get a blank black screen. Can you please help?
Connect direct to the TV and select
TV/video and see if that works
The Ipod does net work connected direct to
video/audio inputs Why dont you see if the
Ipod wlil work on anything connected dorectly
You say the TV already has a problem maybe
the Ipod has a problem also The Tv should
show a blue screen with no signal not blank
You need a good working TV that accepts
video connections Vid/audio VCR, DVD ETC
and then check Ipod on that TV
Since it works on other TV setst why not use
one of the other sets, and have a techiician
look at the Sharp with the video problem
probaly a coupling or filter capacitor or
maybe a bad solder joint There is no
setting that produces a black screen
The IPod player is hooked to the receiver via standard yellow video connection and the receiver only has one connection to the TV, HDMI. All the other video sources that come through the receiver display fine. The same cable works on all other TV when connected directly so I know its not the cable. What do you mean by ipod is not supporting to the TV output? I also have this same problem when I try to hook my security cameras to the SHARP LCD TVs through a modulator and the S-video connection to TVs. They display fine on all other TVs except the SHARPS as well. It has to be a setting on the SHARP TV.
No that doesn't work.
As I stated above the IPod player and Security cameras work fine on all the other TVs in my home.
