Question about GE Refrigerators
I have a GE Side by Side Fridge that is frosting over in the freezer and ultimately doesnt freeze properly. it is model TFX25ZRBWW. How do I repair?
Amigaman
  • 248 Answers
SOURCE: refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Posted on Nov 12, 2007
22yooper
  • 828 Answers
SOURCE: kenmore sideby side fridge
You have a defrost system problem. Defrost is controlled by a timer which energizes the heater circuit. The heater circuit has a radiant or cal rod type heater which melts the frost from the coil. When the coil reaches a temperature where all ice would be gone a termination switch opens and shuts of the heater. The timer will continue to run until defrost time expires (18-22 minutes).
If you can locate the timer there is a clutch head screw to advance the timer to the defrost position. Turn the screw clockwise SLOWLY until you hear one audible click. The heaters should come on and defrost take place. If the unit restarts after the 18-22 minute period the timer is good, if it does not restart advance the screw to a second audible click and it will restart.
If you had to turn the timer the to second click to get it started cooling replace the timer.
If the unit restarted after the 18-22 minutes and defrost did not happen your problem is in the heater circuit. This would be an open heater or bad defrost terminator switch. To access the heater and defrost terminator the back panel in the freezer section must be removed. With an Ohm meter you can check the heater to see if it is good.
Posted on Jul 02, 2008
SOURCE: GE side by side. Freezer cold, fridge kinda cool
i had a similar problem, i found that the small mast on the motor turning the fan was just spinning and the fan was spinning just a little bit because it sits on there. I took the plastic fan off and put tape around the mast of the fan motor and placed the fan back on so it sat on there tightly. The fan blew cold air again because it was able to **** up the cold from the coils again, compared to when it was very loose.
Posted on Jul 07, 2009
garing
  • 998 Answers
SOURCE: freezer cool but not freezing
check your defrost system
Posted on Aug 08, 2009
aasc
  • 1606 Answers
SOURCE: I have GE side by side fridge. The freezer built
Pull refrig out from the wall and unplug . Remove the 8" x 10 " panel covering the main control board . On this board , unplug the blue plug with 3 larger wires going to it . The sequence looks like this : wire1,wire2,space,wire3 . Use a piece of wire , with both ends stripped about 1/4 " , and insert an end into wire2 and wire3 . Plug refrig back in . Look inside the freezer at the back bottom , and see if you see a red glow . It may take about 30 seconds for the glow to appear . If no glow appears , the defrost heater located at the bottom of the coils ( glass tube ) is probably shorted . Pt # WR51X10042 . Also replace the defrost thermostat Pt # WR50X10068 . To access these parts , the inside freezer panel has to be removed . If you do get a red glow , then the main control board is bad Pt # WR55X10656 .
Posted on Sep 04, 2009
Testimonial: "Thank you very much for this imformation it saved me $75.00 which right now I really don't have. Unforntunately the board is bad. Thank You again"
My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Mar 07, 2012 | GE Refrigerators
The freezer freezes on the bottom but only gets cool the upper half.It is a frost free fridge and it is freezing up on the panels. the refrigerator side is not cooling properly.
You have a bad defrost system in this unit. It is simple to repair and we have parts for this model. Just get in touch with us at accurate-appliance-service.com and we will get the correct part out to you right away.
We hope this helps you.
Oct 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Freezer is not freezing its cold like the fridge but thats it. tha fridge is running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Refrigerators
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Nov 30, 2008 | GE GTH18KBR Top Freezer Refrigerator
Fridge is not cooling and now the freezer is not freezing
problem is that the defrost system is not working.
remove back panel inside freezer and you will find pipework is full of ice. melt off carefully with a hairdryer. appliance will now work as this serves as a temporary repair
fault finding is not so easy but check that the defrost heater is not open circuit and check the thermal fuse in series with the heater is ok.
some frostfree are controlled by a simple mechanical timer which can also be faulty. if electronically controlled, you may be looking at a new module. get back to me if you want more help
Aug 07, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
