Question about Weslo Exercise & Fitness
I have a Weslo Cadence M5 treadmill. The belt is slipping every time I try and use it. I have tightened it, recentred it, and lubricated it. Nothing has helped at all. What else can I try?
Walking belt is turning up ever so slightly at the edges, so it might be old - this is a second hand treadmill.
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
  • 103 Answers
SOURCE: my weslo cadence 200 treadmill belt keeps slipping
please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
Posted on Nov 25, 2009
  • 18 Answers
SOURCE: lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Posted on Mar 11, 2010
bwinton
  • 83 Answers
SOURCE: Adjusting the walking belt
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
SOURCE: Walking surface will only move
I have a weslo cadence g40 treadmill. I am having problems with the belt. The machine runs and the belt moves but when I go to step on the belt it stops moving, I have tried to adjust it like the manual stated but nothing seems to help. Any ideas?
Posted on Apr 18, 2011
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
Safety key is inserted into weslo treadmill cadence 825 but belt wont move, it worked for about 5 minutes before it just stopped, felt like belt was slipping, rollers at either end not moving.
hi if you can take off the front pannel where the motor is. its look like the belt on the motor a either slipped off or you need a replacement,
Nov 15, 2010 | Cadence Exercise & Fitness
After walking about 15 seconds the belt slows way down and stops completely.
The walking belt slows when walked on the walking belt maybe overtightened, treadmill performance may decrease and the walking belt may become damaged or the opposite the drive and /or running belt may need tightening. Last thing would be that the belt needs lubrication to be applied between belt and deck.
Apr 26, 2010 | Cadence Weslo 620/630 Treadmill Walking...
Lubricating a treadmill
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
My Cadence 825 is running on walking speed only when I'm on it but speed up when I'm not stepping the belt. It also makes burring sound when switched on and I can smell burning too.This is a 13 year old...
You actually used the opposite treatment that was needed when you used the lubricant spray. You want the belt to not slip but instead grab to the belt driver. Now, the lube should be removed and instead the powder that causes the belt to grab hold should be applied. You may want to call any treadmill store and ask them what they charge to do a maintenance on a treadmill like yours.
Oct 01, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Jan 13, 2009 | Exercise & Fitness
Exercise & Fitness Logo
69 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Jim London
Jim London
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
