No water is coming into the machine and there is water in the pipe
While using washing machine water leaks out
sounds like the lower pipe or pump pipe is leaking or come away. you need to pull the washer out and place it on its side (left as you look at front) and check the pipes on the bottom, they have pincer clamps on the pipes, if the pipes are cracked or damaged replace them but usually its just they have come loose from drum movement. and just need fitting back on. also the drain pipe needs to be at least 3 inches from the top level with the water in pipes height of the washer so the water does not just come out.
Jan 13, 2018 | Washing Machines
Fault 37 call technician
Pump blocked error,
No change in water level,
Is the pump going & water coming out of drain pipe.
Is there still water in the machine.
If no water in the machine.The clear pressure tube to the motor controller is blocked.
Blow air down the pipe to dislodge any blockage & refit the pipe.
Jan 27, 2013 | Fisher and Paykel Washing Machines
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Have hot/cold water pipes coming outside from roofspace in house to garage for washer/dryer. Already had two bursts inside garage and machine and electrics destroyed. New machine installed after...
Insulation only slows down the transfer of heat (cold), it does not stop it. If it is below freezing and the water in any pipe is not moving, it will eventually freeze. Most major industrial supply houses like McMaster-Carr or Grainger in the US, carry pipe tracing tape. It comes in various lengths and you secure it to the pipe under the insulation, plug it in and many types have integral thermostats that keep the pipe above freezing. If you have a washing machine, you will have to consider the lines to the washer valves, both hot & cold and any other areas in the washer that may hold water like the pump and the discharge hoses.
Was this washer always outdoors?
Jan 08, 2011 | Easy Heat Water Pipe Heating Cable
Water slow coming into the tub this happens every time you turn on the washer. We cleaned the screens
Check the water inlet pipe is not kinked or blocked. If you can turn water off, remove pipe, place pipe end in bucket, turn water back on, check flow from the pipe to eliminate it. If not that, then the water control valve in the machine might want replacing. By the way, those horrible "quick connectors" that are sometimes used to screw on to the water pipes, can corrode over the internal hole, and prevent good flow, so replace with a proper washing machine valve, and TEE connector.
Aug 11, 2010 | Maytag Washing Machines
Water over flowing from detergent drawer
If machine is just filling all the time till water comes out detergent drawer then this will be a pressure fault. Most likely a blockage.Unplug your machine and remove the top. You will see a round switch with a number of wires going to it and a thin pipe at the bottom of the switch.This is the pressure switch that controls the level of water. the water goes into the pipe at the bottom and builds up air pressure within the pipe which operates the switch. the water should never come up this pipe to the switch.
You now need to follow this pipe down to the bottom of the machine. There it will be fitted with a small spring clip to a pipe, or small chamber. This is where your blockage will be and you now need to find something to clear this without damaging any parts. When done replace all pipes secure and test machine.Now you are hopefully satisfied that this was your problem. Goodn luck
Mar 12, 2010 | Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Feb 13, 2010 | Hotpoint First Edition WMA20 Front Load...
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Washing machine leaking at the connection to water pipe.
Hi vks1,
Your water is coming out into the washer even when you water supply is switched off at the pipe?
Disconnect the washer hose from the water pipe and see if the water still comes out of the water pipe even when the water valve is shut off!
If the answer is YES!
This is a plumbing malfunction.
The valve on your water pipe is not closing completely!
There is a washer in the water valve attached to the end of the valve stem that more than likely needs replacement.
And not a washer malfunction.
If I understand your explanation correctly this is the cause.
If this is not the problem then the washer has a water inlet that is stuck open.
But this dose not make sense if the external water valve is shut off there should not be water reaching the washer inlet faulty or not!
I believe I figured out the problem for you and you will be fine when the valve is fixed or the valve stem replaced!
Bless You,
Let me know that you have succeeded!
Happy to of helped you.
Please give me a good rating before you sign off our site!
Thank You
Sep 10, 2008 | Estate TAWX700JQ Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
