Question about AEG Ovens
Will the AEG NC7013001M double built under oven fit into a space 56mm wide between two units?
  • 184 Answers
SOURCE: Wall Oven does not fit flush into built in cabinet
I HAVE SEEN SOME CABINET MAKERS BUILD A TRIM PIECE THAT GOES ALL THE WAY AROUND THE EXISTING HOLE THAT HAS AN OUTSIDE DIMENSION LARGER THAN THE CABINET HOLE AND AN INSIDE DIMENSION TO FIT THE REQUIREMENTS OF THE OVEN. IT ATTACHES TO THE FACE OF THE CABINET AND STAINED TO MATCH THE CABINET FINISH.
Posted on Apr 10, 2008
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Posted on Sep 15, 2008
jyackle5
  • 8197 Answers
SOURCE: fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
sclarke7
  • 222 Answers
SOURCE: Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Posted on Aug 27, 2009
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
Defy slimline eyelevel oven installed in cupboard.
Assuming it is an electric built in or built under oven, these are commonly fitted into a dedicated cupboard (oven housing) that matches the other kitchen units and typically little or no facility for ventilation is provided.
Electric ovens are usually so well insulated and covered with reflective foil the need for ventilation is minimal, especially when a standard size oven is fitted into the correct standard sized housing as it will provide an air-space of an inch or more all around.
It can be expected the housing near the top of the oven will become warm after a while and the shelf above likely to become warm enough to soften a candle but if it gets hot enough to actually melt a candle I think that is rather too hot. The addition of additional insulation and reflective material should improve matters greatly.
I suggest you approach the guy who fitted the oven if it was professionally fitted. It would have been his responsibility to only fit a suitable appliance and if additional ventilation was required he should have advised you.
I believe I have seen some oven housings with a slim grille over the oven and it is probable there would have also been a slot cut at the rear and perhaps a short piece of trunking to carry warm air away from the space directly above the oven.
Mar 30, 2016 | Ovens
Will a GE built in oven JT3000DF fit in the space that has a Kenmoore build oven in that space at this time 9114105559 part number
Simple. Measurements. Unless i'm missing something here.
Take present oven detailed measurement, compare it to the newer oven's detailed measurement.
Feb 03, 2015 | GE 30" Built-In Single Electric Wall Oven...
Have a Kenmore Elite Built-In oven 790.4812. It's a double oven. Was working fine. 1 year old. Wife self-cleaned upper oven for first time. Oven does not work now. Sears Repair guessing that the oven...
It has nothing to do with the tight fit.
It has everything to do with self-cleaning on ovens.
The thermal fuse blows due to extreme temperatures.
Replace the fuse to use the oven.
Use an oven cleaner to clean the oven OR replace more fuses in the future.
Jul 25, 2011 | Ovens
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
How do i replace the element in the bottom oven of an AEG U3100-4 cooker ?
If it is a fan assisted oven, remove the screws securing the rear cover inside the oven compartment, remove cover, and you should see the oven element there.
Undo the element, and fit new one.
Aug 04, 2010 | AEG U3100-4 Electric Double Oven
Oven cuts out after ten minutes and comes back after cooling down.
thermal cut out fuse, costs about £30, my company fits them for £78 all in in essex
Nov 19, 2007 | AEG B3101-4 Electric Single Oven
Ovens Logo
Top AEG Ovens Experts
ashburton
Steve
Chris Hall
Chris Hall
Are you an AEG Oven Expert? Answer questions, earn points and help others
