Question about Nokia Cell Phones
My nokia rm-975 wont turn on it only makes a buzzing noise what do I do to fix it.
    New Friend:
  • 4 Answers
Visit mobile Service center in velachery
iTools mobile Service center
No 73 velachery main road velachery
chennai 600042
Posted on May 12, 2017
  • 979 Answers
SOURCE: Spngbob TV Makes buzzing noise when plugged in and wont turn on
Bad horizontal driver or output transistor/trnsformer. Look for serious service for this set...accordianman
Posted on Oct 20, 2007
  • 479 Answers
SOURCE: it makes buzzing noise and doesnt work
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
click the link http://www.repairclinic.com/0088_11_1.asp#Level1_5
Posted on Dec 11, 2008
duf542
  • 5 Answers
SOURCE: my 19 inch ge tv makes buzzing noise can it be
I've had this happen on a couple of TVs, it's always been from moisture getting into the back of the TV. I've been told by a few techs that the issue is beyond economical repair on older televisions.
Posted on Mar 14, 2009
SOURCE: says card cover open when turning on.makes a buzzing noise then shuts back off
you should have either dropped it down the floor or it should have been affected with water or solvents. the only way is you have to take it to the service centre to change the lens array.
Posted on May 27, 2009
  • 1937 Answers
SOURCE: wont spin and makes a buzzing noise in all cycles.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26912691
and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
Since the washer will drain the problem is not in the Lid Switch (which tends to happen quite often with these washers)
The problem does however point to the Neutral Drain Assembly.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
The buzzing sound that you hear could be the small cams in the assembly trying to connect with the main spin gear.
Ours had basically the same problems.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
See the following for how to access the transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 25, 2009
Bobbin not threading
Please give us more information. Are you trying to wind thread onto the bobbin or trying to stitch and the needle is not picking up the bobbin thread?
Feb 26, 2018 | Sewing Machines
Free unlock code for rm-975
I was not able to get a free unlock code for the mobile model that you have specified. I suggest you can approach Wickedunlock.com and specify the country, locked network of phone .Based on the availability you can get the permanent unlock service along with free instructions.
Jan 04, 2018 | T-Mobile Cell Phones
RM975. How can I unlock?
Steps to Enter AT&T Nokia RM-975 Free Unlock Code
  1. Insert new network SIM in AT&T Nokia RM-975 phone.
  2. Turn on the AT&T Nokia RM-975 phone. it will show Unlock Code screen.
  3. Enter the AT&T Nokia RM-975 FREE Unlock Code and then press unlock.
Apr 05, 2016 | Nokia Cell Phones
How to reset nokia model:RM-975
NOKIA X RM-980 HARD RESET - YouTube
? 2:48
https://www.youtube.com/watch?v=p1MvDSvg0eI
Jun 9, 2014 - Uploaded by ??? ????????? ???????.
NOKIA X RM-980 HARD RESET. ... Como desbloquear NokiaLumia 630 Model:RM-977 Pantalla bloqueada Cricket - Duration: 6:32. by ...
Nokia Lumia 635 - How to unlock security lock by hard reset ...
? 13:59
https://www.youtube.com/watch?v=3HPlTPXQP5k
Sep 22, 2014 - Uploaded by phone reset
Nokia Lumia 635 - How to unlock security lock by hard reset. phone reset ... Unlock AT&T Nokia Lumia 635 (RM-975) - AT&T Unlock Code ..
RM-974/RM-975 - Factory Resets
www.factoryresets.com/.../how-to-hard-reset-nokia-lumia-635-rm.html
Feb 27, 2015 - Before you decide to Hard Reset Nokia Lumia 635 (RM-974/RM-975), please test the following process to repair your mobile. First step charge ...
Dec 03, 2015 | Nokia Cell Phones
Oct 19, 2007 | Emerson SpongeBob SquarePants TV
Cell Phones Logo
64 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
