Question about Lumix Cameras
Good afternoon.have a lumix fz100 will not hold charge replaced battery and charger it is 5 year old
  • Lumix Master
  • 3,000 Answers
Hello Peter Southey,
Before you throw the whole thing over your shoulder
consider that our world supply of BATTERIES are
riddled with counterfeits... and your NEIGHBORHOOD
CAMERA SHOP is also as likely to be victimized
as the average eBay novice...
It is a GLOBAL PROBLEM... I'm not saying your camera does not have a TROUBLE... just suggesting a likely scenario
(I have personally experienced).
My best suggestion here is to look closely at that new battery before you despair completely...
First step...
check out TRUSTED SELLERS on eBay
AMAZON...
(as in any MARKET) great as their return policies are...
you can get hurt on unit cost and shipping if you are
not paying attention (in my humble opinion).
Carnac the Magnificent
Posted on May 12, 2017
The battery on my 92 acura legend will not stay charged...alt is good, battery charger wont ven charge it!!! is it the posts???
If battery does not hold charge it probably needs to be replaced I don't know the age of the battery but if it is over 5 years old it's probably time for a new one hope this helps also you can take it to your local auto zone or advanced and they can do a battery test to see if the battery is actually the issue but it sounds like it is
Apr 26, 2014 | 1992 Acura Legend
Lumix dmc-fz100
Remove the battery for 15 mins, replace the battery then go to the camera's Menu and set the Date & Time.
Mar 14, 2013 | Panasonic Lumix DMC-FX01 Digital Camera
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Our one year old ZS3 calims all of a sudden "No battrey power remains", even that the battery has been freshly charged. The charger and the Voltmeter show a full battery. So where to start ? a...
Hi, My best guess would be that the battery isn't actually holding a charge anymore. I'd suggest trying a different battery as that should solve the issue.
Jul 21, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
The battery charger in the trasfer case is not charging the battery
have you tested the battery to see if its a good one? if its a dud it wont charge up, and whet tests have you done to see if it realy is not charging the battery, the times iv had this,,, its not charging,,, when it was, but the battery was a dud,
however check all the fuses and trips and put an avo meeter set to amps x10 in line with the battery after you have started the charget to see if it realy is not charging up,,, if its not look at the rectifier,,it may have a blown diodes in it
Nov 05, 2009 | Watts Onan Portable Generator - 5000 ,...
My camera lens isn't working, how can I reset it?
it sounds like there is dirt, dust or something else in the lens mechanism. I'm assuming you don't want to take the camera to a repair shop. I've had several cameras and this issue comes up periodically.
You can try:
1. using compressed air (with as thin a nozzle as you can find) to blow out the dust,
2. try powering on the camera and zooming the lens at the same time, 3. gently knocking the camera on a hard surface to loosen the lens mechanism,
4. manually forcing the lens to go back in. This can potentially damage the camera, but it's not working now, so you don't have a lot to lose.
5. Googling the camera model to see if you can find instructions on opening the camera up to clean the lens mechanism.
Oct 09, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
My old battery will no longer hold a charge after I charged it
I had the same problem look a fuels next to the batter replace it , then you be good to goooooooooo.. good luck
Aug 15, 2009 | 1994 BMW K 1100 RS
Cameras Logo
47 people viewed this question
Top Lumix Cameras Experts
teddyboy
Lawrence Oravetz
Are you a Lumix Camera Expert? Answer questions, earn points and help others
