Vms screen frozen with error on screen - Computers & Internet
Where can i driver download?
Go to the Veho Download Centre:
select "Drivers and Software"
then "Microscopes"
then "VMS-004 400x USB Microscope".
There are zip files for two versions: first download the pdf that explains how to choose the correct zip file.
May 01, 2014 | Veho VMS-004D 400x USB Microscope...
My laptop screen devided into 8 seperate screens
unfortunately not possible, unless you want to install VMware and you can have 8 different VMs running onscreen
Aug 10, 2013 | HP Pavilion dv2000t Notebook
Need a manual for VWR VMS-C7 hot plate thanks!
May 11, 2012 | VWR Vms-c7 Hot Plate
We need to set up a voice mail for an extension that has not been used in years. When I press intercom 777 and enter extension it tells me to enter password which no one in the office knows anymore. When...
The default password on partner voicemails is 1234. The reason for the call returning to the extension that transferred the call to the new extension is probably because the cover vms isn't set up for the new extension.
To check the vms cover for that extension, at either extension 10 or 11 press feature 00 and press the left hand intercom button twice. The display will say system programming.
Enter #310, the display will sayAutomatic VMS Cover Extension:
enter in the extension number of the new extension.
The screen will say either "1 assigned" or "2 not assigned"
enter in 1 (assigned)
press feature 00 when finished.
Sep 30, 2010 | Avaya Corded Phone avaparp18d
Setup vms dcps print queue for a xerox phaser 8500 -can't do pcl
Can you update this with the VMS version please.
Mar 30, 2010 | HP Computers & Internet
The phone rings 3 times and goes to voicemail on the 4th ring. How do I change it to pick up on the 8th ring?
I don't think its a good idea to back the vms cover rings to 8. The furthest I'd go is maybe 6.
Changing the VMS cover rings on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#321"
the display should say VMS Cover Rings and ask for an extension number
enter the extension number you wish to change
The current ring data should be displayed
enter in new data (8 ring if you wish)
press feature "00" to logout
Dec 10, 2009 | Lucent PARTNER18 Corded Phone
Recognising floppy disk drive type on DS10
the Only VMS post on fixya ever.
wow. from the dark ages of DEC. VMS. OS.
sounds like bad drive if it can not be mounted.(or disk bad)
sounds like you are 42 years behind the upgrade curve too...
i used to work on all DEC systems. so know that . 1975
the DS10, is now 18 years old.
here is a relic manual, on that
is this your only DS10, of not try the drive on system #2?
ahh its now called OPENVMS,, amazing thing that is.
open vms was ported to ALph chips. 1992
then 2001 port of OpenVMS to the Intel Itanium architecture
so it's an 17 year old OS.
get HP proliant Server G7 up. and win. for sure.
Dec 13, 2017 | Compaq AlphaServer DS10
My rca isnot working. when i turn it on it says "fat error plz connect vms device format"
I am having the same exact problem. It just happened last night and I'm trying to figure out why it's doing it.
Nov 16, 2006 | RCA Lyra RD1072 MP3 Player
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
