My siotech Model STL 32 VN 67 DT TV doesn't turn on straight away when I push the Standby button. It can take up to 1 hour for it to turn on.
    Top Expert:
  • Televison & ... Master
  • 74,990 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on May 12, 2017
Wont turn on from standby
Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 40BV801B LCD TV
Tv wont switch on with remote or the button on top of the tv. The standby button is on (red). sometimes it comes on by itself and switches off by itself (onto standby mode) not sure of the model as its a...
It could be one of a couple of problems really, the first one may be that your analogue signal is being switched over to digital which is happening across the UK at the moment, buying a digital receiver would resolve this straight away. It could be a problem with the ariel connection to the TV, check that its all pushed in properly at the back of the TV. Failing this then its a problem with the TV set, the fact that the set produces a picture on other sources (dvd) implies that if it is a fault with the TV its with the ariel connection.
Mar 31, 2011 | Sanyo Televison & Video
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
Standby light blinks twice after turning itself
this a code that mean overvoltage in power supply (+B)
Mar 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Mar 18, 2010 | HP Televison & Video
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Tv doesnt always come on straight away
Need more input, what model, what brand, do it turn on if you hit the side.
What About Bob
Feb 19, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
