What can I do to make it work or isn't it fixable
Water well ice maker
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Posted on Mar 08, 2008
SOURCE: Ice maker
I am having the same problem with mine.
Posted on Jul 15, 2008
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
SOURCE: Frigidaire Ice Maker not working
I have a Frigidaire side by side refrigerator freezer MRS20WRGW0. I had the thermostat-defrost replaced yesterday. Now the ice maker isn't working, doesn't have water in the "tray" part that makes ice, but does still dispense water through the door. What could be causing this problem?
Posted on Mar 28, 2011
Fridge isn't cooling
Its defrost issue.The defrost assembly parts are not functioning right causing the problem.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Side by Side Refrigerator
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
My Ic13b icemaker but when ice tray is full it still adds water to icemaker causing it to overflow and freeze on bottom of freezer
either your ice maker is calling for too much water or the water valve isn't shutting off when the ice maker tells it too. The best thing to do is to change both the ice maker and the valve because if one is defective more than likely thee other will fail shortly
Jun 05, 2012 | Amana Refrigerators
Kenmore 106.56666500 ice maker not working
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
This will help. Thanks. Helpmech.
Oct 31, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
What's your problem?ice maker isn't working
Assuming the coils underneath the ice box are clean and the ice box freezer section is running under normal operating conditions so that the ice mold thermostat can close contacts @25F, their are 2 suspects. The ice maker itself and the ice maker's water supply valve. Most of these supply valves have 2 solenoids for ice maker and water through the door. If the water valve is ok then the ice maker is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 27, 2011 | Kenmore Side by Side Refrigerator
Hi just bought a Samsung RSG5PUBP fridge freezer it is all plumbed in and the water function works but the ice maker does not. So far it has been on for 24hours. Any ideas???
Most ice makers require you to lift the metal arm up, for it to activate! Not in a straight (horizontal) position! But level (vertical) with ice container. Like resting on top of container, but not touching.
If this isn't the case, than you really need to check the water line going to the ice maker in the back of the refrigerator...check all connections, and trace the water line all the way to sink. You may have a blockage somewhere, or possibly a faulty ice maker?
These are usually, the main troubleshooting tips for ice makers!
Kind Regards!
Sep 10, 2011 | Refrigerators
Water thru the door does not work
First, is your ice maker making ice normally? If it is then you have water. If it isn't then it might be time to replace the water filter! If the ice maker IS working then it has to be either the dual water valve solenoid or the switch.
Jun 16, 2011 | GE Refrigerators
Ice is frozen solid in ice maker,will not fall out into dispensor
Most profiles use the electronic ice makers and when they stop like that usually means the complete ice maker needs replaced. The part number is WR30X10093. There are no fixable parts. I had to just buy one myself. Sea Breeze
Apr 28, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker problem
something has to give when it too hard to turn. if ice cubes are ice to each other it could cause this . sometimes this is caused by water leaking from ice maker into the bucket . look for a bad water valve or a ice maker that is not lever or has bad tray . . ****
Jan 19, 2010 | Refrigerators
Ice maker does not make ice. Water supply works, but ice machine is dry.
if it is the ice maker in the door, it's a bad ice maker....we do a lot of them
Nov 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
