Question about Refrigerators
My icemaker keep flashing on medium and don't wanna change. Keep flashing medium
2 Suggested Answers
  • 4 Answers
SOURCE: asb light and brack keep flash and i have had pads changs
im pretty sure its your fluid level (steering) screw top as you stand infront of car right hand side screw top with metal connector attached
Posted on Feb 12, 2009
I own a 2001 Chevy unpalatable and it work fine and everything but the blinkers don't wanna seem to work properly its like 95% they don't work as for the other 5% the blinkers only wanna work when...
Make sure all outside blinkers are flashing at one speed, if not check the bulbs and all connections, If that doesn't work check flasher
May 09, 2013 | Cars & Trucks
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 28, 2010 | Keurig B100 Coffee Maker
About mobile flashing
Hello i hope u 'll be fine.... thanks for usingfixya.
To know about mobile flashing
Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Apr 17, 2010 | Nokia 6600
Dont wanna see somebodys posts or any activity
Yes, friends who write lots of posts can be annoying. Just click 'Hide' next to one of their posts and you'll be asked if you want to Hide the person, which you do. You shouldn't see any more of their posts, but you're still friends.
Apr 14, 2010 | Computers & Internet
ITS SAYS ENTER PUK CODE
Dude, call up Customer Care....n get it!
Btw, if u enter ur PUK wrong 3 times...ur sim will be permanently blocked!!
[ If ur a Vodafone customer, then u call up cust. care at 111....or, 9886098860...for any other fone!(toll free) ]
Then, follow instructions and enter ur phone no.....They'll tell u ur PUK....
The fone then asks u to enter ur new PIN no. ......n confirm it!
If u wanna keep ur PIN code then it'll ask u for the new PIN dat u entered each time u switch on ur cell!!
if u don wanna keep it, then go to Menu>Settings>Security>Sim Pin....(unmark it...it'll ask u for ur PIN again)....
Sep 19, 2009 | Cell Phones
Nokia 5130 pin blocked problem
Doesn't it ask u for a PUK code?....heres wat u gotta do....!
Call up Customer Care....n get it!
Btw, if u enter ur PUK wrong 3 times...ur sim will be permanently blocked!!....so be Careful!!
[ Its a Recorded msg mostly.... ]
Enter ur PUK,
if u don wanna keep it, then go to Menu>Settings>n to whereva u disable ur PIN code....n try not to 4get ur PIN code.....
If u can't remember it ....then keep it as four zeroes ( 0000 ).....this is usually the initial PIN no. when u get a new phone!
Sep 19, 2009 | Nokia 5310 Cellular Phone
DJM 400 Keep going into over on the channel and the master volume
To keep your levels down keep the TRIM don which is the gray knob. Also keep the hi, mid, and low knobs at the medium level. The control cables are for using the fader start function.
Jun 02, 2009 | Pioneer DJm 400 Professional DJ Mixer
Ice not ejecting led flashing
Open the freezer door look at flashing led. Now on the left side is a flapper push that in with your hand be sure to keep your hand out of the way of the hole . where the led is now should be solid red. If it isnt then you need new optics. If it is then open the flapper in front of the icemaker at the top of the freezer. You should see the icemaker running width wise in the freezer. You may need a step stool for this next step. The icemaker should have what i call teeth pointing upwards at a 45 degree angle towards you. If these teeth are pointing down in the ice then you need a new module. which is behind the white cover of the icemaker on the left.. Hopefully this helps. Usually the gear head is broken on the module but of course you will have to remove it to find out. Happy hunting
May 27, 2009 | Refrigerators
Sony - KV24FS100
Do you wanna repair it by yourself? How many times stand-by light flashing?
Jul 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
