I have an error code 06 on a siemons edition 150 washing machine. E-NR WM6147EGB/01 and I can't find my manual. Can anyone help please? I've tried getting the manual online to no avail!
KMusselmann
  • 247 Answers
SOURCE: error code on Welbilt ABM3400 breadmaker
Here is where you can get the manual but it does not have any error codes in the manual. It does however have a service phone number.
http://www.scribd.com/doc/261890/Complete-Welbilt-Bread-Machine-Manuals#
Hope this helps you
Kurt
Posted on Mar 18, 2009
57 varieties
  • 1653 Answers
SOURCE: Hotpoint WF840 W machine still full of water error code F 05.
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
barkencoa
  • 3463 Answers
SOURCE: f-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Thanks.
Posted on Nov 18, 2009
  • 20 Answers
SOURCE: I BOUGHT A USED ASPIRE 3100-5100 MOTHERBOARD AND
You should try clearing the cmos battery. It's a small battery on the motherboard that can be taken off. Take it off for 20 minutes and put it back in. Then boot up again.
Posted on May 05, 2010
blueextc3221
  • 15935 Answers
SOURCE: error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Hi, can sb please help I'm looking for a user manual for my w/machine Bosch E-nr # WFM2010/08 in English. Thank you
According to Bosch (http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html) it's not yet available online. You can order most original instruction manuals through the Customer Service Replacement Spare Parts department by calling 0344 892 8979 (UK) or (01) 450 2655 (ROI).
Jan 20, 2015 | Bosch Washing Machines
How can i fix my hotpoint wt940 with F-01
Hi Hayley,
Please help us help you. Expand on what is working and what is not. SO please add to your comments and repost.
First things first. Water is always a hazard with electricity. Please turn of the power source to your machine and do a fine cleanup, Take canister vacuum and get the hard reach places. A large box fan will help dry the machine and the floor. Pull the machine away from the wall. If possible lift the top off the machine to allow air flow and a panel cover for examination. a hair dryer can be used to dry electronic components in the event of an overload. Give it a chance.
If the machine restarts and is faulting. Here is a link to diagnose the coding Error Codes Hotpoint Service
F01 - Short circuit motor triac*
Here is a place for an online repair manual Free Online HOTPOINT Washing Machine Repair Manual
Here is the Hotpoint manual conversion site Download Manual Hotpoint Service
It appears you may need a new module if the cleanup does not clear out the code
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3336-hotpoint-first-edition-hvl-series-washing-machine-and-washer-dryer-error-codes.html
Fare. Well.
Jan 05, 2015 | Hotpoint Washing Machines
Telewest codes gone off eurovox in tyne and wear
Pure NTL (54 01) Updated 06/10/2009
KEY 00 = A0 51 3B 27 17 7D D0 28
KEY 01 = F0 CF C3 01 F1 2D AB B8
Ex CW (5C 01) Updated 06/10/2009
KEY 00 = BC B6 BB DD 97 AD 11 63
KEY 01 = 42 B7 84 3E BE 8C 4E 65
TW (5A 01) Updated 06/10/2009
KEY 00 = C2 B5 BE 41 0D 9B C5 7C
KEY 01 = 6D EA 8E 97 6A AA DA 71
Oct 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
Has anyone got latest ntl codes 54 01 area please 6/10/09
C & W 5C 01] 06/10/09
Telewest 5A01 06/10/09
NTL 54 01] 06/10/09
00 =A0-51-3B-27-17-7D-D0-28
Oct 06, 2009 | Televison & Video
Does anyone have the eurovox codes for liverpool area for today (06/10/09) please?
NTL 54 01] 06/10/09
C&w codes gone again can anyone help pls?
NTL 54 01] 06/10/09
try one of these bad boy good luck
Telewest Codes for 26 February 2009
hi here are codes at 25/2/09
00= aa b7 d1 d9 ce 8e 83 af
01= a1 38 06 29 24 29 8d 2b
hope u get and running.
Feb 26, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox code please 29/01/2009
Hope this does,
C & W -- 29/01/09
5C 01
00= 7D 9B 0E 8B 69 3F E7 34
01= 83 61 00 3A FD F3 DC 0A
Telewest -- 29/01/08
5A 01
00= E7 D3 69 2E 6F 38 EA 78
01= A1 38 06 29 24 29 8D 2B
NTL -- 29/01/09
54 01
00= 2E E9 B1 3F F7 F8 53 B2
01= 9F 09 00 66 3B D2 43 8B
Jan 29, 2009 | StarTech.com StarView SV211K 2-port KVM...
Codes for eurovox max telewest/virgin bradord area
5a 01 North west
00- aa b7 d1 d9 ce 8e 83 af
01- a1 38 06 29 24 29 8d 2b
Sep 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
LATEST STARVIEW TELEWST CODES
latest starview codes for august 2010 are for telewest 5A01
KEY 00 = CF 53 0C 33 79 61 71 85
KEY 01 = 52 5E 8D 45 FC 75 F6 4A
Jun 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
