Question about Janome Sewing Machines
How to successfully use monofilament thread on Janome Horizon 7700
I am wanting to attach sashing to a multi coloured scrap quilt using monofilament thread.
  • Janome Master
  • 12,063 Answers
Generally, it is better to use monofilament in the top, not in the bobbin. There is also a problem with tension so our instructor had us tape a paper clip vertically about midway between the spool pin and the first thread guide on the top of our machine, set the spool behind the machine in a small cup and ran the monofilament through the paper clip and threaded as normal.
Posted on May 14, 2017
Quilting bar guide keeps slipping....janome horizon 7700
The guides I'm familiar with have a screw to tighten them onto the presser foot.
Aug 12, 2017 | Janome Sewing Machines
How do I adjust tension on a Janome 1600p-qc for machine quilting?
Adjust the tension the same way as sewing regular projects. You want the top and bobbin threads to meet in the middle of the quilt sandwich. When quilting, I use a lighter weight thread so I have a separate bobbin case whose tension has been tightened specifically for quilting. For other sewing projects using a standard thread weight, I use a bobbin case that is factory set and then adjust the top thread tension for each project.
Aug 04, 2017 | Janome Sewing Machines
Janome Memory Craft 8200QC Horizon. Can you get a stitch regulator? How does it work? Does it help to free motion stitch ?
You should check with a Janome dealer if your machine can use a stitch regulator. Machines that take a stitch regulator need the ability to plug into the machine, which is not available on a lot of machines unless they have the stitch regulator function. A stitch regulator helps some people. It still takes a lot of practice moving the fabric smoothly.
On my BSR, it has an "eye" that measures the distance the fabric moves under the presser foot so it can stitch at the specified distance. The faster the fabric moves, the faster it stitches, but the stitches tend to more uniform in length.
FWIW, I read a summary of the Janome 8200 QC Horizon and there was no mention of a stitch regulator.
http://freemotionquilting.blogspot.com/2011/05/piecing-quilting-on-janome-horizon-7700.html
Mar 11, 2017 | Janome Sewing Machines
Thread disappears up into the machine and out of the needle when using automatic thread cutter
  • It may be that there are quite a few thread ends in the mechanism. Remove the needle plate and pick out any detritus you may find. The cutter normally clamps down on the cut end to stop the issue you describe.
  • You are advised in the manual to use the thread cutter on threads of #30 or thicker, so it might not grip the thread once it is cut if you have thinner threads than the mechanism can cope with (or the threads are slippery)
  • If you are piecing patchwork I'd advise having a little heap of small scraps next to the machine. Then you can run onto a small scrap at the end of each seam and start the next seam without having to cut the threads each time. You work like making a string of flags and cut them off later.
Mar 13, 2015 | Janome 7700 QCP Sewing and Quilting...
Is there a special type of monofilament thread to use?
I would suggest that you don't use this thread, it is too fine for the tension device on a domestic sewing machine, and they just don't like it. Too strong, too fine. Its best used in industrial blind hemming machines, if you look at RTW trouser hems you'll often see monofilament utilised here.
Feb 23, 2015 | Elna Quilter's Dream 6003Q
How to fix Janome 7700 bobbin jams ?
Check your upper threading, don't touch your bobbin tension, it has nothing to do with thread tangling on the bottom of the cloth.
Jul 16, 2014 | Janome 7700 QCP Sewing and Quilting...
-what causes bird nest with the Janome Horizon 7700 sewing machine?
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 05, 2013 | Sewing Machines
Sewing Machines Logo
43 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
