Question about Janome Sewing Machines
How to sew successfully using monofilament thread on Janome Horizon 7700
3 Suggested Answers
SOURCE: -what causes bird nest with the Janome Horizon 7700 sewing machine?
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Posted on Apr 06, 2013
99rannellis
  • 11756 Answers
SOURCE: I have a janome Horizon 7700. I have a different colour thread on top than I do in the bottom. The top thread is showing on the bottom. What should I do.
Tighten the top tension--righty-tighty!
Posted on May 25, 2017
Quilting bar guide keeps slipping....janome horizon 7700
The guides I'm familiar with have a screw to tighten them onto the presser foot.
Aug 12, 2017 | Janome Sewing Machines
How to successfully use monofilament thread on Janome Horizon 7700
Generally, it is better to use monofilament in the top, not in the bobbin. There is also a problem with tension so our instructor had us tape a paper clip vertically about midway between the spool pin and the first thread guide on the top of our machine, set the spool behind the machine in a small cup and ran the monofilament through the paper clip and threaded as normal.
May 12, 2017 | Janome Sewing Machines
I am using the new Bernina #72 foot on my B530. It seems to have a clicking sound with each stitch. Is this normal? I don't know if it's the hopping or in the needle area.
I've noticed that presser feet with the spring to create the hopping action will sometimes make a clicking sound. Just verify that it is not the needle hitting something it shouldn't.
Mar 11, 2017 | Janome Sewing Machines
Janome Memory Craft 8200QC Horizon. Can you get a stitch regulator? How does it work? Does it help to free motion stitch ?
You should check with a Janome dealer if your machine can use a stitch regulator. Machines that take a stitch regulator need the ability to plug into the machine, which is not available on a lot of machines unless they have the stitch regulator function. A stitch regulator helps some people. It still takes a lot of practice moving the fabric smoothly.
On my BSR, it has an "eye" that measures the distance the fabric moves under the presser foot so it can stitch at the specified distance. The faster the fabric moves, the faster it stitches, but the stitches tend to more uniform in length.
FWIW, I read a summary of the Janome 8200 QC Horizon and there was no mention of a stitch regulator.
http://freemotionquilting.blogspot.com/2011/05/piecing-quilting-on-janome-horizon-7700.html
Is there a special type of monofilament thread to use?
I would suggest that you don't use this thread, it is too fine for the tension device on a domestic sewing machine, and they just don't like it. Too strong, too fine. Its best used in industrial blind hemming machines, if you look at RTW trouser hems you'll often see monofilament utilised here.
Feb 23, 2015 | Elna Quilter's Dream 6003Q
How to fix Janome 7700 bobbin jams ?
Check your upper threading, don't touch your bobbin tension, it has nothing to do with thread tangling on the bottom of the cloth.
Jul 16, 2014 | Janome 7700 QCP Sewing and Quilting...
Apr 05, 2013 | Sewing Machines
Can i use monofilament nylon thread with the 1600p series machines ?
Yes. Loosen the tension a bit and then test on like fabric until you get a satisfactory stitch.
Mar 18, 2010 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
