I wish to replace my remote control for the TV a Panasonic. The remote has G code printed on the front. The keys won't work any longer so wish to renew. Where can I get one?
SOURCE: remote control codes
i have a oneforall urc-7530 controll and need a code for a panasonic tv
Posted on Dec 19, 2007
ginko
  • 19396 Answers
SOURCE: Need a code for Soniq
Are you using an universal remot to replace original?
Posted on Mar 28, 2008
  • 6 Answers
SOURCE: Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Posted on May 01, 2008
ShadeTek
  • 81 Answers
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
  • 3 Answers
SOURCE: Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Posted on Dec 30, 2008
I have try several times to connect my Welby big button remote control to my Panasonic TV.I have the codes of the TV but I can't get it to work.can someone guide me thru.I will appreciate it.
[PDF]Big Button Universal Remote Control User's Manual
www.magnifyingaids.com/pdfs/Big-Button-Manual.pdf
Big Button functions just like your original remote ... On the remote control, press and hold the MODE button (TV, VCR, CBL/SAT or. DVD) until the .... Q. Why won 't my Big Button work? A. Make .... PANASONIC 008, 051, 057, 076,. 149, 247 ...
[PDF]Big Button Remote Control Set-up Codes - ValuNet
myvalunet.com/.../Remote-Control-Big-Button-Remote-Set-up-Codes.pd...
Innovative System's Big Button Remote Control ... TV. Quick. Number. Manufacturer/. Brand. 0. SANYO. 1. SONY. 2. SANSUNG. 3. LG. 4 ... PANASONIC. 6.
Remote Control Setup, Codes and User Guides - FiOS TV ...
https://www.verizon.com/.../tv/.../remote+contr...
Verizon CommunicationsThis page provides links to setup instructions, remote control codes, user guides, ... No code for my device ... Want to buy the Verizon P283 Big Button remote?
Amazon.com: Gmatrix Big Button Universal Remote Control ..
Dec 14, 2015 | Panasonic Televison & Video
How to program a rcr804bfdr to a sanyo tv
Programming the RCA RCR804BR or RCR804BFDR Series Remote Control
Programming with Direct Entry:
To program your remote to control up to four components, follow these steps:
  1. Manually turn on the component you wish to program the remote to operate.
  2. Find the four-digit code for your brand of TV, VCR, DVD, satellite receiver, cable box, or digital TV converter in the enclosed code lists.
  3. Press and hold the CODE SEARCH key until the indicator light turns on.
  4. Release the CODE SEARCH key.
  5. Press and release the TV, VCR or SAT·CBL·DTC key. The indicator light blinks and then remains lit. Note: DTC references digital TV converter. To program the DVD·AUX key: Press the DVD·AUX key. To control a DVD, press the VCR key. To control a TV, press the TV key. To control a satellite receiver, cable box, or digital TV converter, press the SAT·CBL·DTC key. The indicator light stops blinking and remains lit.
  6. Enter the four-digit code, using the numeric keypad. After the code is entered, the indicator light turns off. Note: If the indicator light blinks multiple times, you've entered an invalid code. Start from step 2 again.
  7. Aim the remote at the component and press the ON·OFF key. The component should turn off. Note: If your component does not respond, try all the codes for your brands. If the codes do not work or your brand is not listed, try the Code Search Method that follows.
Programming with Code Search:
If your TV, VCR, DVD, satellite receiver, cable box, or digital TV converter does not respond after you have tried all the codes for your brands, or if your brand is not listed, try searching for your code via the Code Search Entry Method. To program your remote via the Code Search Entry Method, follow these steps:
  2. Press and hold the CODE SEARCH key until the indicator light turns on.
  3. Release the CODE SEARCH key.
  4. Press and release the component key you wish the remote to control- TV, VCR or SAT·CBL·DTC key. The indicator light blinks once and remains lit. Important: Find the ENTER key on your remote (don't press it yet). You will need to press this key quickly in step 6 below. To program the DVD·AUX key: Press the DVD·AUX key, followed by the component key you wish the DVD·AUX key to control. For DVD, press the DVD·AUX key, followed by the VCR key. For an auxiliary component, press the DVD·AUX key, followed by the corresponding component key ( TV, VCR, SAT·CBL·DTC ).
  5. Press and release the ON·OFF key until the component turns off. Important: You may have to press the ON·OFF key up to 200 times.
  6. As soon as the component turns off, press the ENTER key within 4 sec- onds. The indicator light turns off. Note: If you wait longer than 4 seconds to press ENTER, the remote goes to the next code-you will need to start the code search from step 1 again.
Dec 24, 2014 | RCA Televison & Video
NEED A CODE FOR A SANYO CRT TV WITH A SANYO REMOTE
0854,0347,0223,0548,0532. Try these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Panasonic Televison & Video
Lost code book for large Brookstone remote for a Panasonic TV
Setup codes to check with Panasonic brand tVs are 0093,0037,0019,0035,0083. If you wish to get more setup codes to Panasonic brand TVs, check these links.
Feb 25, 2013 | Brookstone 538744 Remote Control
My tevion 43081 32" tv won't work with the codes on the universal remote
Code to check with Tivion TV is 0198. If you wish to get more details, check this link. It has setup code list to different brands of remote controls from which you can choose.
Feb 13, 2013 | Televison & Video
I've got a Universal Remote Control PLUSTRON URC11E-8A. I don't know how to make it work with my TV
Here are the steps for you to program your remote control to your Panasonic TV.
  1. Press the [SET] key and hold it, then press the TV key.
  2. The LED will be on at the moment. Then release the pressed both keys.
  3. Enter in the 3-digit Device Code.
  4. If the entered Device Code is correct, the LED will be off automatically. If it is incorrect, the LED will blink once and keep being at setup mode (being on). Then please return to step 3.
  5. Try if keys on Remote Control work or not. If most keys work improperly, please try other code, repeat 1~5 till you find the main keys work good enough.
The code for Panasonic TV are 020, 024, 061
Jun 13, 2010 | Panasonic Televison & Video
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Code for a Panasonic TV/VCR
Hello, Urpurdy -
Am I safe to assume you have the user manual (in printed / paper format) for the RCA RCU600WMS remote control? If you do not, you can find it and download and save the PDF document here: https://voxxintl.zendesk.com/hc/en-us/articles/225306867-Information-User-Manual-and-Code-List-for-the-RCA-RCU600WMS-Universal-Remote-Control . You can then print it from the saved document. Tip: I suggest you set up a file folder in your computer Documents folder, titled: RCA TV Remote (or something like it, so you can find it whenever you may need it.) Also, I print the user manual out and keep it near the TV for future reference.
The user manual includes the programming instructions and code lists starting on page 6 (PDF page 4).
Best wishes.
Dec 17, 2017 | RCA RCU600WMS Remote Control
Lost codes for 4 in one used for universal remote control
DRC800 Sanyo TV 0799,0154,0893 Panasonic VCR 0035,0162,1062,0616,0225,1035 press device key for 6 seconds led will blink solid key in code correct code will cause led to blink 3 times press power button to confirm code works. rg
Sep 09, 2007 | Philips 8-Function Universal Learning...
Televison & Video Logo
Top Televison & Video Experts
