Question about Rowenta Irons
MY ROWENTA SREAM IRON DW9080 BURST OF STEAM DOEESN'T WORK BUT SPRAY BUTTON DOES. WOULD LIKE TO FIX MYSELF WITH INSTRUXTIONS
micromaster
  • 3614 Answers
SOURCE: ROWENTA PROFESSIONAL
Try to check the wire connecting to the switch from the steam unit,.,,
Posted on Jun 07, 2008
  • 240 Answers
SOURCE: Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Posted on Jun 11, 2009
  • 1015 Answers
SOURCE: No water released from iron when burst of steam or
The jets might be clogged with minerals from hard water. Try using some vinegar in it to see if it breaks up the minerals. You might need to let the vinegar sit in the water resovoir of the iron for a little while. Also use vinegar on the jet holes where the watre comes out of the iron.
Posted on Oct 28, 2009
heatman101
  • 43501 Answers
SOURCE: Spray Starch sticking bottom of iron leaving black residue
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Posted on Jul 15, 2010
DiYerTech
  • 70 Answers
SOURCE: I own a Rowenta Steamium
Not familiar with that newer model, but here is the local dealer who is most helpful in California:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Posted on Sep 13, 2011
Rowenta DW9080 Auto/Off stuck. How do I bypass the Auto/Off feature, or find a replacement switch?
thermostat defective,,,can be do drect by expert professional,,,but it will burn your all clothes due to very hot position,without auto cut
Nov 13, 2014 | Rowenta DW9080 Steamium 1800-Watt Steam...
Jun 07, 2008 | Rowenta Professional DX8900 Iron
Clogged steam holes
If the approved cleaning procedure does not work, your Rowenta iron may have failed.
Jan 09, 2014 | Irons
I own a Rowenta Steamium DW9080 steam iron. I need a replacement plastic door for the water reservoir. The iron is functional and I do not feel it necessary to purchase the entire handle and cord...
Aug 29, 2011 | Rowenta DG-980 Iron
How to clean
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Aug 22, 2011 | Rowenta DW9080 Iron with Auto Shutoff
Rowenta DM-880 steam button sticks. Spray button works fine. Any ideas? Thanks.
It is possible that there is dirt that has accumulated into the stem of the steam button and is sticking the button. It is better to remove the lid and make a good cleaning to free the movement. use good spray of jet air, use WD40 to remove dirt and free
This will work for sure.
Aug 21, 2010 | Rowenta Professional DE880 Iron
No water released from iron when burst of steam or additional spray of water buttons are pushed
Oct 28, 2009 | Rowenta Surfline Iron DE-333 Iron
Jun 11, 2009 | Rowenta Professional DX8900 Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Irons Logo
54 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
