Question about Garden
New Ozito chain saw kill switch problem as cannot take the brake. Off
dennisgladx
  • 52 Answers
SOURCE: poulan chain saw 295 pro.
Hi pietras 1,
My name is Dennis and I would like to help but what I think may be a problem, has to be confirmed visually, so I can only give you a guess where I'm going with this. The kill switch is a ground wire for the ignition so the magneto current will not jump the gap at the plug. If the ground wire is disconnected from the kill switch the ignition will not be grounded out then you request it to be grounded. Now if this wire that is disconnected is entangled with the rod that connects the throttle to the carburetor that could be the reasonthe machine is a run-away. Look at the linkages in the area ofthe kill switch and see if this makes sense.
Please rate the solution because I depend on you for your rating to help me learn toassist correctly.
Posted on Nov 07, 2008
SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
Posted on Dec 31, 2008
  • 61 Answers
SOURCE: Stihl ms290 chain runs constantly even when idling
Mindreader was correct to sugest the clutch. also check the needle bearing on the clutch casing where it runs on the crank shaft. the sprocket should be able to turn without turning the crank shaft. If it is tight, change the bearing
Posted on Oct 12, 2009
  • 4088 Answers
SOURCE: Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
MOTORWIZJ
  • 1363 Answers
SOURCE: Husqvarna Chain saw 460 rancher chain brake problems
THERE LINKED TOGETHER SOUNDS LIKE, TAKE THE SIDE PLATE OFF THE SAW AND BLOW IT OUT WITH COMPRESSED AIR, THIS I THINK WILL SOLVE THE PROBLEM . IT'S JUST A GOOD IDEA TO BLOW OUT THE SAW AFTER EVERY USE .THINK SAFETY !1. JAY THE POOL PUMP GUY IN LONGWOOD FL
Posted on Feb 03, 2012
How do I change blades on ozito 210mm compound saw
hopefully this manual helps.
There are pictures and instructions on changing the blade, starting on page 15.
http://cdn0.blocksassets.com/assets/ozito/ozito-product-manuals/VFIW5zKsTiAxHGZ/CMS-210.pdf
Oct 27, 2017 | Saws
Where can i get a replacement switch for a ozito mitre saw
from ozito spares or service agent
Aug 26, 2017 | Saws
My ozito electric chain saw won't start; what seems to be the problem?
If you are sure you have power going to the saw then there is a chance you have over worked the little electric motor and burnt it out. I know I did that once by forcing it because the blade was dull.
May 29, 2017 | Electric Garden
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
How to replace a kill switch on a husky 288 xp
There should be only 1 screw and one wire connecting the kill switch. The kill switch simply grounds out the ignition. So it is difficult to install improperly. The wire coming from the switch goes directly to the ignition module.
Jun 21, 2014 | Husqvarna 288 Kill Switch Wire Chainsaw...
Setting carb
The fuel tank vent is built into the body of the saw. There is a plug cover of the fuel tank vent valve adjustment shaft just in front of the saws handle on the right chain drive side of the saw. Seek a professional.
Nov 17, 2013 | Husqvarna 288 Kill Switch Wire Chainsaw...
New uc3520a chainsaw will not work
240VAC European Model
From the Makita manual:
If the saw does not start when the ON/OFF switch (1) is actuated, it will be necessary to release the chain brake.
- Pull the hand guard (6) firmly in the direction of the arrow until you feel it catch.
electric motor does not function
no power supply
cable defective
chain brake actuated
Mains fuse blown
HTH
Lou
If these don't work return it, maybe it is defective. Test the new one in the store.
Oct 18, 2009 | Makita UC3530A 14" Electric Chain Saw
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
