Question about Ricoh Office Equipment & Supplies
Hi Everyone i really need Technical help here i have 3 Ricoh Aficio SG 2100N Printers they worked very well even with the ink converted to sublimation refillable containers...
But Now i have stumble on some problems like the instead if showing the error the Machine throws me with SC 20200, 28111 or other type of errors
SOURCE: ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
Posted on Jun 05, 2008
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Posted on Jun 26, 2009
Ricoh c6501 sp error coad sc 925 solution
SC925 B Net File function error *GW The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. The HDDs are defective and they cannot be debugged or partitioned, so the Scan Router functions (delivery of received faxes, document capture, etc.), Web services, and other network functions cannot be used.
HDD status codes are displayed below the SC code: • Refer to the four procedures below (Recovery from SC 925). Here is a list of HDD status codes:
Display Meaning (-1) HDD not connected (-2) HDD not ready (-3) No label (-4) Partition type incorrect (-5) Error returned during label read or check (-6) Error returned during label read or check (-7) "filesystem" repair failed (-8) "filesystem" mount failed (-9) Drive does not answer command (-10) Internal kernel error (-11) Size of drive is too small (-12) Specified partition does not exist (-13) Device file does not exist
Procedure 1
If the machine shows SC codes for HDD errors (SC860 to SC865) with SC 925, do the recovery procedures for SC860 to SC865.
Procedure 2
  1. If the machine does not show one of the five HDD errors (SC860 to SC865), turn the machine power off and on.
  2. If this is not the solution for the problem, then initialize the NetFile partition on the HDD with SP5832-11 (HDD Formatting - Ridoc I/F).
    NetFiles: These are jobs printed from the document server using a PC and DeskTopBinder. Before you initialize the NetFile partition on the HDD, tell the customer:
    • Received faxes on the delivery server will be erased
    • All captured documents will be erased
    • DeskTopBinder/Print Job Manager/Desk Top Editor job history will be erased
    • Documents on the document server, and scanned documents, will not be erased.
    • The first time that the network gets access to the machine, the management information must be configured again (this will use a lot of time).
  3. Before you initialize the Netfile partition with SP5832-11, do these steps:
  4. Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
  5. In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
  6. Do SP5832-11, then turn the machine power off and on.
Procedure 3
  1. If "Procedure 2" is not the solution for the problem, do SP5832-1 (HDD Formatting - All)
  2. Cycle the machine off/on.
Apr 12, 2016 | Ricoh Office Equipment & Supplies
Juki lh-4128sf error 303
hi there,
regarding LH-4128SF JUKI double needle machine error E303, if you are using control model SC-920, SC-921 it means E303 Semicircular plate sensor
• Semicircular plate sensor signal cannot
be detected.
• Check w h e t h e r t h e mach ine head
corresponds with the machine type setting.
• Check whether the motor encoder connector
is disconnected.
if still error E303 coming please contact me.
best regards
Jul 04, 2014 | Juki Sewing Machines
What do I need to do in order to "Scan to Folder"?
Jun 13, 2014 | Ricoh Aficio SG 3100SNw - multifunction...
Resetting sc542 error
Fusing thermistor defective or out of
• Fusing lamp open
• Fusing thermostat open
• Fusing thermofuse open
• Power supply board defective
and for reset use prog 5-810 as follow
Resets all level-A service call conditions, such as fusing
errors. (To reset SC 547, switch the machine off/on.)
[0 = No / 1 = Yes]
• After selecting "1", press the Original Type key and the
' key (or OK key) at the same time to execute the
reset. If the reset is successful, the display shows
"Action completed." If the reset fails, the display shows
Apr 22, 2014 | Ricoh Aficio 1018D Copier
57000 error
please my SG 3110DN printer came up with this error code : SC 57000
Jan 06, 2014 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Sc (28112) error
I have a ricoh SG 3110 DN error code 28112. Can I fix this?
Dec 07, 2013 | Ricoh Aficio Sg 3110Dnw 29Ppm
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
37 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
